unless you use your own tank water. Sounds silly but I've done it plenty of times at my folks place.
It feels a bit strange though, before you can rinse off the car you have to turn on a powerpoint for the pump lol
https://www.sau.com.au/forums/topic/238135-diy-carwash/#findComment-4164084
so even the car washes where you pay people to wash it for you. Is that water recycled?
If so this would mean its not legally possible to wash your car with clean water ?
Well the water is treated etc etc.
Its probably cleaner than the water that comes outta your tap.
https://www.sau.com.au/forums/topic/238135-diy-carwash/#findComment-4164269
Last night i went to the carwash just to use the high pressure hose to wash some dust off the rear bar and today i noticed residue; kinda like a mineral residue.
Had to use a bucket to wipe it off just before.
Never again will i use it.
https://www.sau.com.au/forums/topic/238135-diy-carwash/#findComment-4165794
