mythbusters ahoy!
standard powerfc
FUEL CUT on REV LIMIT (which is set via hand controller) (or datalogit) - there is no other way to adjust it
powerfc pro
SPARK CUT on REV LIMIT (which is set via hand controller) (or datalogit) - there is no other way to adjust it
+ also with launch control
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4166359
ok well i did it, i set it to 6950 last night.
two things.
1. even tho it was set at 6950 it still spiked out to 7215rpm when i hit the rev limit hard. is that normal?
and
2. Does it hurt the engine or anything bouncing it off the limiter?
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4167152
do you have to turn car off and back on again to get the settings to stay in?
i've not fiddled with a power fc for a while
tho maybe not true, as i remember sitting at lights and adjusting the launch control (gti-r) and that changed right away. now there was a few funny looks from other motorists, Bang bang bang bang!
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4167209
No
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4167443
if the engine couldn't rev happily to 8000rpm they wouldn't have put the factory rev limiter there.
So what I said about the factory limiter being at 8000RPM is correct?
Why the hell lower it to 6950 then!!! It's CRAZY TALK!
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168053
ive been told that 8000 is way to high and should reali be kept around 7000revs... so daily i wouldnt need any more then that.
Just being safe..
On a daily car, it is fine.
On the race track, stick a bit lower down. (This is why the ex bathurst GTR ran a 7000RPM limiter on race day, but during prac/qual ran 8000RPM...)
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168121
also dude, if its your daily, how many times in a day are you going to be bouncing off you rev limiter?? im sure you will give it a squirt here and there, and if you do, having you rev limit at 7500rpm is fine, even 8000rpm! but just dont sit there and bounce, obviously then you asking for trouble. with these motors, in first and second you still pull when hitting 6500 - 7500 or so, so if your changing gears early, then you wont be inside your torque range in the next gears.. and so on...
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168137
so your saying hitting 7000rpm on a daily basis is fine?
Is this a trick question or a very silly one?
Not sure... so im gonna reply with one of my own
You sit on the limiter daily driving?
No.
So of course its fine for a daily driver.
Bouncing of a 7k limiter would be FAR WORSE than reving the car to 7500rpm and changing naturally.
You often come here with some misinformation, so wherever you keep getting it from, you need to stop going there or talking to that person.
7500rpm would be FINE. However, are you making power there on the stock turbos? Probably not that much so changing from 7k-7.5k would be the spot
https://www.sau.com.au/forums/topic/238257-power-fc/page/2/#findComment-4168229
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
