Any updates?
Was going to ask you the same thing.
My engine has to come out of the car this weekend, few things going on thats put this project on hold for a little while. Once the new ecu goes in il be back to running E85
The race gas vs E85 issue is the reason I'm keen to back-to-back test 110RON Martini vs E85. I'm aiming to do this prior to the Xmas holiday period.
Sunoco costs me $10/litre...how keen do you think i am.
Do you have enough injector for it, Paul?
my new runners from Hypertune have injector bosses on both top and bottom.
two sets of 1000cc injectors should cover it.
Edited by DiRTgarage
6 lengths of garden hose will do the job too and far cheaper :(
Seen a few highpowered cars running E85 on Friday night. Smells sweet exiting the exhaust :P
Im keen to get my car tuned on it now.
Any updates Anthony?
Whats your economy like now?
I am in the middle of changing ecu's.. so i am back on 98. last tank i got 460km's so worked it out to be 13 litres per hundred with 98.. with e85 my best was about 420km's to a tank.
The servo just past the Meccano set near Landsvale is refusing to sell E85 to the public . They claim (counter jockeys) that the government won't let them do so and that the company (Manildra Group ?) is only selling to people with certification .
Any idea whats going on ?
A .
There is another servo (albeit the same company) a few minutes away that sells E85 (corner of Ferndell St and Rawson Rd, South Granville). I might swing by over the weekend and see what is the G-O with the E85.
  • Like 1
Hi GT , there was an Asian lady and an Indian looking feller behind the counter and no power on earth was gonna get me the E85 pump keys .
I tried to explain to them that all I wanted was 4 liters but the answer was no no and no . They said that the last time I got my 4 liters was a mistake and it should not have been sold to me at all .
Just for the record I had ~ 40L of straight Shell 98 ULP and wanted to make it "E10" . I could not get through to them that 4 of 40 is 10% (yeah ok 4 of 44) and no I didn't want the usual low grade E10 mouthwash .
I left contact details but not confident I'll get a return call or message .
I think we need to find a way of accepting responsibility for what we buy otherwise the alconazis are going to make life difficult .
A .
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
