Any updates?
Was going to ask you the same thing.
My engine has to come out of the car this weekend, few things going on thats put this project on hold for a little while. Once the new ecu goes in il be back to running E85
The race gas vs E85 issue is the reason I'm keen to back-to-back test 110RON Martini vs E85. I'm aiming to do this prior to the Xmas holiday period.
Sunoco costs me $10/litre...how keen do you think i am.
Do you have enough injector for it, Paul?
my new runners from Hypertune have injector bosses on both top and bottom.
two sets of 1000cc injectors should cover it.
Edited by DiRTgarage
6 lengths of garden hose will do the job too and far cheaper :(
Seen a few highpowered cars running E85 on Friday night. Smells sweet exiting the exhaust :P
Im keen to get my car tuned on it now.
Any updates Anthony?
Whats your economy like now?
I am in the middle of changing ecu's.. so i am back on 98. last tank i got 460km's so worked it out to be 13 litres per hundred with 98.. with e85 my best was about 420km's to a tank.
The servo just past the Meccano set near Landsvale is refusing to sell E85 to the public . They claim (counter jockeys) that the government won't let them do so and that the company (Manildra Group ?) is only selling to people with certification .
Any idea whats going on ?
A .
There is another servo (albeit the same company) a few minutes away that sells E85 (corner of Ferndell St and Rawson Rd, South Granville). I might swing by over the weekend and see what is the G-O with the E85.
  • Like 1
Hi GT , there was an Asian lady and an Indian looking feller behind the counter and no power on earth was gonna get me the E85 pump keys .
I tried to explain to them that all I wanted was 4 liters but the answer was no no and no . They said that the last time I got my 4 liters was a mistake and it should not have been sold to me at all .
Just for the record I had ~ 40L of straight Shell 98 ULP and wanted to make it "E10" . I could not get through to them that 4 of 40 is 10% (yeah ok 4 of 44) and no I didn't want the usual low grade E10 mouthwash .
I left contact details but not confident I'll get a return call or message .
I think we need to find a way of accepting responsibility for what we buy otherwise the alconazis are going to make life difficult .
A .
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
