my setup needs some attention. I am running the stock mspec front bar and have not chopped out the reo bar because i like my car to be legal.
The oil cooler is mounted on the front of the air con condensor, so its heating up there, i added a air con thermo fan and have replaced the clutch in the engine fan.
Its just that the radiator cannot get enough air from the front. its a Mspec radiator as well.. I need to move the oil cooler and install another thermo fan i think.
Try fitting an alloy radiator and a Nismo thermo stat.
Sounds like i have a similar set-up to yours, but i have cut the reo :), and my temps are mainly stable at 64-68deg. The highest i have ever seen it was 86deg at a drift day.
PS: Bonnet vents help alot too ;)
Who did you get to fill in the missing bits around the inside edge of the bar openeing?
A plastic welder in East Keilor, VIC.
I think they have closed down since, but you should be able to find one in the yellow pages.
im keen to give it a go on the track, will c the EPA about it considdering the fact that i have no cat... ill need to do some mods before she is finished however will need a good tuner. Guilt-Toy seems to have his head screwed on with loktite lol might see him about it....
Sounds like i have a similar set-up to yours, but i have cut the reo :banana:, and my temps are mainly stable at 64-68deg. The highest i have ever seen it was 86deg at a drift day.
PS: Bonnet vents help alot too :)
nice setup! i do have a alloy radiator, its a mspec one. my temps are okay on a 40deg day when my air con is off, as soon as i turn the air con on the temps go through the roof... got up to 102deg today (cycle idle was off)
I got a new genuine nissan thermostat as well.
My oil cooler is on the other side so my fan is where your oil cooler is.
are you running a rediator shroud? I broke mine and havent been able to find one recently and I find my temps sit around 86' compared with 81' when I first fitted the ally radiator with shroud
Hey Al have you got more pics of your car somewhere its on f*kin clean gtst!
yes i i do have the shroud.. seems my car runs a bit hotter for some reason... might try some better coolant or move the oil cooler? my oil cooler is heaps bigger then that one on Als car
not to mention a std air box
his injectors are maxed out tho, he should think about an upgrade, i suggested sard 850's would give some nice headroom.
Just an update for those interested, i have noticed this thread has been a bit quiet of late.
I have sold the 555's and in the process of purchasing SARD 850's (should receive mid next week).
Also purchasing 24psi actuator off a fellow member which i should recieve early next week also.
POD filter has just been bolted back on.
Be interesting to see how it goes holding the 24psi boost with plenty of fuel and air. Adrian will be tuning again (your a legend mate whats this make it 5 or so now). If it feels noticeably different it will getting run up on the same dyno again. If not it can wait til next months dyno comp.
I'll add my 2c too.
We finally fired up my RB25DET at the end of last week using 910cc inj' and running E85 for the first time.
Scaling ~25% fuel out of the map for the old 550's saw it start up and purr away like a kitten.
And now that the Adelaide temp's have dropped from 'insanely hot' to mid 20's I'm expecting a dyno number sometime next week. Still have to do a bit of tidying up after the rail and injector change, but it all looks neat enough.
:) Ha-ha. He's a man with a memory like an elephant. I was considering upgrading the cement to top quality 300*300*40 pavers, as not only do they give a nicer Autosalon style boot display, but they also allow more adjustment in weight distribution :)
GT: May I suggest attempting to swap your radiator for a stock Koyo one?
Have seen issues from Alloy rads not dispersing heat properly.
Either that, or chuck a volt meter in the coolant whilst engine is running, and against battery earth... Do not let the probe in the water touch metal of radiator.
Then do a test from rad itself to battery neg...
If you get a voltage usually about like 0.5Volts on either, throw an earth strap on the rad.
you mean a stock nissan one? i do have a spare actually.. and as for the earth, i already have a earth strap on it.. put that on a couple of weeks after i got the alloy radiator...
I am getting one of those swirl pots, to go on the cooling system. when i turn the car off i can hear bubbling in my coolant system.. just noticed it.. maybe the top mount turbo is causing air in the line and causing the extra heat?
is it bad to run the engine at 100deg? or 97?
Brief stints at those temp's are nothing to be majorly concerned about, but if it's a regular occurrence I'd be looking at rectifying the situation, GT.
It's not something simple like a dud radiator cap is it - I know it's one of the first checks you would do, but I thought I'd ask.
Bubbling is also an indicator of head gasket or head problems which would also cause it to run hot.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
