I was having severe issues on the Manildra blend at anything under 15 degrees, now on Caltex it will start fairly easily, only a little cough and splutter but on the first crank or two. The issue is I cant give it a bit of pedal at startup with the stupid electronic throttle.
A.C.T dude...
Constant below zero mornings here in winter grrr
E70 would probably be needed then :)
I got back from Canada about a month ago, they all use electric oil warmers in winter on Petrol motors and Diesels pretty much don't start when it's really cold haha
Temperature ranged from -10 to -38deg :blink:
Edited by SimonR32
LOL. Interesting, our hire car in Utah didn't have problems starting when it was -12 one morning....
The Springvale pump does the same thing, just hang it up and start again. It seems to do it when they don't enable the pump quick enough.
I always use the pump closest to the shop/office. The other pump is screwed. I've tried hanging it up and starting but its still slow as hell...
Has anyone done any tests on smaller amounts of e85 mixed with PULP?
Say 10 litres of e85 with the rest pulp? I now a few guys have done E30 blends but have required retunes.
I was wondering if adding a smaller amount say the last 10 litres worth in a full tank be worth it or a waste of time. Could you get away with this small amount without having to have a retune done?
Cool. Might have to look into getting a retune.
I have highflowed 600cc injectors. If i were to get a retune to run straight E85 would these injector be maxed?
SR20det
600cc injectors
NIstune
Full zorst
2871r
Walbro Pump
Making 210rwkw on 16psi
SR20det
600cc injectors
NIstune
Full zorst
2871r
Walbro Pump
Find out from your tuner what duty cycle your injectors are running at, that will tell you. Or get a diagnostic cable and install nistune and find out for yourself.
I think you will be fine running straight E85 on 600cc injectors!! Joeyjoey was running 300rwkw on E85 with 550cc injectors. That seems to be one of outliers but still I cant see why 600cc injectors couldnt run 240-250rwkw on E85??
SR20 4 banger not a 6cyl RB.
jono/harey/trozzle. you guys are cracked. no way can you make that much with only 4, 600cc injectors. my 4 nismo 555cc injectors in my silvia are pretty much maxed at 240kw on PULP. you can get 250kw on 4X600cc on pulp but to do an E85 tune you're going to need 850s at a min. I'd go even bigger if you want to pull some decent power too.
Completely didn't think about the fact it's a 4 cyl :P
yer i highly doubt they'd be big enough for straight e85
im not on as much crack as the other 2.....
There's definitely an E85 shortage in Adelaide.
United have stopped selling it, Caltex is the only one selling it at the moment.
Hopefully the ethanol supply picks itself up after the floods in QLD
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
