I paid 1.27 yesterday at Blaxland, but the week before I paid 1.08, so yeah it's up and down with ULP it seems.
Seems to be determined by location too! As ive paid 10-15c differnce on the same day between Sydney and Newcastle :/
Caltex better not be shutting down the eflex supply
Otherwise there goes my hopes of running it, united servos that stock it are too far from me
I have to travel to Heathcote from Wollongong with 10 jerry cans,so that means I will have to go to Campbelltown,but its worth it. :yes:
A couple of pages back I spoke of replacing the R33s Z201 filter and its EFI hose .
After trying unsuccessfully to stop fuel leaks below the fuel filter I have again replaced the filter and refitted the standard rubber hose below it .
I am f**ked if I can work out how 5/16 EFI hose is larger than 8mm since 5/16" is from memory 7.93mm ? Its OD is larger than std and it slips over the steel line barbs way too easily .
Can someone confirm that std EFI hose is 8 or maybe 7.5mm because everyone wants to sell you 5/16 stuff .
A .
  • 1 month later...
How's everybody's cold starts going with e85? Is it really that difficult to start when cold??
It's not too bad, only on a really cold morning do I have any issue, and all it takes is a little pump on the the throttle as I crank it and it fires up, it's really fine.
United Minto have had issues with the Ethanol content. Ill post an update once it gets sorted.
Fires first crank ;)
I've been running eflex for a year now
It's fine starts first go every time only in the winter can't really accelerate to quickly for the first minute have to ease the acellerator on or just let it sit for a minute starts and idles good first go still
In summer can start it and go straight away
Kirawee was around the 1.14 today .
Question . Are people using that sensor from Haltech , which is a "Contenital" branded thing if you search , using those GM plastic quick connectors on them or just clamping on EFI hose ? If I had to do that I think I'd plumb it to the low pressure return side of the reg .
Cheers A .
i'm giving the proflow nylon plastic quick connect a go, i did a bit of research and nylon is ethanol safe. It's also on the return line so low fuel pressure but will keep a close eye on it regardless. Disco did you sort out your fuel hose issue?
Edited by linkems
In summer no issue, in winter with cold start fuel dumping in you could perhaps flood the engine. No big deal as the plugs won't foul anyway, just let it sit for a while if it floods and it will start fine.
Dumping twice as much cranking fuel in the engine, mine still has some issues at under 10 degrees. Obviously the lower the compression and further south you are, the worse off you will be. It really chuggs through the ethanol doing short school runs in winter...
Running the EMU previously I had no cranking enrichment table. I had to fit a stock injector into the plenum, with a 1L petrol reservoir and old stock fuel pump to get me started in the mornings. It worked well.
I'm starting to think water meth is a better idea than e85. No cold start issues, more k's to the tank, no jerries in the back on long trips. Perhaps even running 98, a secondary e85 tank and another set of injectors might work out better for me.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
