I paid 1.27 yesterday at Blaxland, but the week before I paid 1.08, so yeah it's up and down with ULP it seems.
Seems to be determined by location too! As ive paid 10-15c differnce on the same day between Sydney and Newcastle :/
Caltex better not be shutting down the eflex supply
Otherwise there goes my hopes of running it, united servos that stock it are too far from me
I have to travel to Heathcote from Wollongong with 10 jerry cans,so that means I will have to go to Campbelltown,but its worth it. :yes:
A couple of pages back I spoke of replacing the R33s Z201 filter and its EFI hose .
After trying unsuccessfully to stop fuel leaks below the fuel filter I have again replaced the filter and refitted the standard rubber hose below it .
I am f**ked if I can work out how 5/16 EFI hose is larger than 8mm since 5/16" is from memory 7.93mm ? Its OD is larger than std and it slips over the steel line barbs way too easily .
Can someone confirm that std EFI hose is 8 or maybe 7.5mm because everyone wants to sell you 5/16 stuff .
A .
  • 1 month later...
How's everybody's cold starts going with e85? Is it really that difficult to start when cold??
It's not too bad, only on a really cold morning do I have any issue, and all it takes is a little pump on the the throttle as I crank it and it fires up, it's really fine.
United Minto have had issues with the Ethanol content. Ill post an update once it gets sorted.
Fires first crank ;)
I've been running eflex for a year now
It's fine starts first go every time only in the winter can't really accelerate to quickly for the first minute have to ease the acellerator on or just let it sit for a minute starts and idles good first go still
In summer can start it and go straight away
Kirawee was around the 1.14 today .
Question . Are people using that sensor from Haltech , which is a "Contenital" branded thing if you search , using those GM plastic quick connectors on them or just clamping on EFI hose ? If I had to do that I think I'd plumb it to the low pressure return side of the reg .
Cheers A .
i'm giving the proflow nylon plastic quick connect a go, i did a bit of research and nylon is ethanol safe. It's also on the return line so low fuel pressure but will keep a close eye on it regardless. Disco did you sort out your fuel hose issue?
Edited by linkems
In summer no issue, in winter with cold start fuel dumping in you could perhaps flood the engine. No big deal as the plugs won't foul anyway, just let it sit for a while if it floods and it will start fine.
Dumping twice as much cranking fuel in the engine, mine still has some issues at under 10 degrees. Obviously the lower the compression and further south you are, the worse off you will be. It really chuggs through the ethanol doing short school runs in winter...
Running the EMU previously I had no cranking enrichment table. I had to fit a stock injector into the plenum, with a 1L petrol reservoir and old stock fuel pump to get me started in the mornings. It worked well.
I'm starting to think water meth is a better idea than e85. No cold start issues, more k's to the tank, no jerries in the back on long trips. Perhaps even running 98, a secondary e85 tank and another set of injectors might work out better for me.
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
