I paid 1.27 yesterday at Blaxland, but the week before I paid 1.08, so yeah it's up and down with ULP it seems.
Seems to be determined by location too! As ive paid 10-15c differnce on the same day between Sydney and Newcastle :/
Caltex better not be shutting down the eflex supply
Otherwise there goes my hopes of running it, united servos that stock it are too far from me
I have to travel to Heathcote from Wollongong with 10 jerry cans,so that means I will have to go to Campbelltown,but its worth it. :yes:
A couple of pages back I spoke of replacing the R33s Z201 filter and its EFI hose .
After trying unsuccessfully to stop fuel leaks below the fuel filter I have again replaced the filter and refitted the standard rubber hose below it .
I am f**ked if I can work out how 5/16 EFI hose is larger than 8mm since 5/16" is from memory 7.93mm ? Its OD is larger than std and it slips over the steel line barbs way too easily .
Can someone confirm that std EFI hose is 8 or maybe 7.5mm because everyone wants to sell you 5/16 stuff .
A .
  • 1 month later...
How's everybody's cold starts going with e85? Is it really that difficult to start when cold??
It's not too bad, only on a really cold morning do I have any issue, and all it takes is a little pump on the the throttle as I crank it and it fires up, it's really fine.
United Minto have had issues with the Ethanol content. Ill post an update once it gets sorted.
Fires first crank ;)
I've been running eflex for a year now
It's fine starts first go every time only in the winter can't really accelerate to quickly for the first minute have to ease the acellerator on or just let it sit for a minute starts and idles good first go still
In summer can start it and go straight away
Kirawee was around the 1.14 today .
Question . Are people using that sensor from Haltech , which is a "Contenital" branded thing if you search , using those GM plastic quick connectors on them or just clamping on EFI hose ? If I had to do that I think I'd plumb it to the low pressure return side of the reg .
Cheers A .
i'm giving the proflow nylon plastic quick connect a go, i did a bit of research and nylon is ethanol safe. It's also on the return line so low fuel pressure but will keep a close eye on it regardless. Disco did you sort out your fuel hose issue?
Edited by linkems
In summer no issue, in winter with cold start fuel dumping in you could perhaps flood the engine. No big deal as the plugs won't foul anyway, just let it sit for a while if it floods and it will start fine.
Dumping twice as much cranking fuel in the engine, mine still has some issues at under 10 degrees. Obviously the lower the compression and further south you are, the worse off you will be. It really chuggs through the ethanol doing short school runs in winter...
Running the EMU previously I had no cranking enrichment table. I had to fit a stock injector into the plenum, with a 1L petrol reservoir and old stock fuel pump to get me started in the mornings. It worked well.
I'm starting to think water meth is a better idea than e85. No cold start issues, more k's to the tank, no jerries in the back on long trips. Perhaps even running 98, a secondary e85 tank and another set of injectors might work out better for me.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
