  • 2 months later...
IN my experience the 32 is just easier to slide lol, mind you anything is easier then the ae86 i drive now, i guess people use 32's more because, they're cheaper, more of them, more options in parts like body kits cos u know a kits inportant to drift with lol, but out of all the cars ive driven my top 3 easiest was, r32, r31 and S13 but even in saying that, it all depends on the setup and the type of driver you are.
Dunno if that helps but yeh.
Edited by stefan.o
  • 7 months later...
what i dont get is how people dont drift them due to size and weight issues - its weird if the japanese think this aswell as they absolutely love cefiros, jzx100 etc etc
if a big old cefiro family car can slide well why not an r33...
btw great thread keep updating with pics/ vids
  • 5 months later...
What about the JMS R33 drifter that became Mark Phillips ppg then martini drift car? That car was mental. I remember the first time i went to a drift event at Mallala I saw that 33 tearing up the main straight. That car was awsome
they were good times and dont forget port gawler lol
  • Like 1
  • 1 month later...
Ceffies and Jxz100s are both smaller and lighter than an R33.
The 33 does has plenty of potential though as shown by the pics/vids above
A chaser lighter than a 33..hmmmm.
Toyota Chaser 2.5i Tv^in-turbo 24V photos
Type : L
Doors : 4
Places : 5
Disposition of cylinders : R6
Disposition of engine : Fl
Volume : 2491
Diameter of cylinder : 86,0 x 71,5
Degree of compression : 8.5
Valves : 4
Disposition of shaft : dohc
Power supply system : EM
Pressurization : TA
Power PS (kW) : 280(206)/6200
Torque : 363/4800
Type of drive : H
Transmission manual : 5
Transmission automatic : 4
Front suspension : QL.FB,QS
Rear suspension : ML,SF,QS
Hydro : +
Break : Si/S
ABS : +
Tyre pressures : 205/55 R 16 V
Wheelbase, mm : 2730
Track : 1485/1495
Size Length x Width x Height: 4750 x 1750 x 1390
Mass equipped : 1450
Mass full : 1725
Volume of trunk : n.a.
Mass of trailer : n.a.
Volume of tank : 70
Dispersial 0-100 km/h : n.a.
Max speed : n.a
Cost of fuel 100 km : 8,5
Fuel : Sb
  • Nope 1
  • 4 weeks later...
lol all you guys that have experienced all the different chassis and models are lucky...
i ha ve to say r33 is easy to drift but thats comparing to my old cars, a vx with a spool and a volvo 360 glt..... the 33 was amazing haha
would love to try an s chassis if what everyone says is true..
i think the long wheel base makes it more fun
Edited by PaulosECR33
, My r33 is built for drifting, its got all the basics, 2-way diff, pinapples, 255kws,9point cusco saftey 21 cage, big fat rims 18x10's with phat offset..
I think r33's are good for drifting, its the way you drift, your style.
here are some videos of me drifting at winton.
and some photos
Uploaded with ImageShack.us
Edited by geraus
