i just finnished giving mine a clean and they came up pretty clear ive tried 4 different products and the best 1 that ive used is the meguiars mirror glaze proffesional series number 17 clear plastic cleaner in a little white bottle 236ml and its the best ive used its almost got rid of all the crap on the headlights will need 2 do a little bit more 2 get it clear as im a bit drunk 2 get it done properely :P
  • Replies 46
Posted Images
I'll be able to correct those just as in the pics Daniel (Goshn) has posted.
Most R34's have this issue and most of the time it's on the outside of the lens.
I can't correct the pitting though, just the minor scratches & the faded/oxidised film on the outside, they'll be clear again.
Please make a booking on 9387 8008 and we'll have her fixed up :down:
Cheers,
d.
do a lot of country driving?
I've done a bit, they're not stone chips though. It's as though the plastic has been stressed somehow. Like miniature cracks all through it.
Email replied to Damian.
For those wondering, the Meguires PlastX stuff works a treat, i was extremely sceptical but i went down and bought a bottle of it today and an applicator pad, they came up looking like a brand new set of lights minus a few stone chips, definatly worth the $19, will post pics if anyone is interested when i get them off my phone
  • 2 months later...
ive tried plastX, scratchX & even normal polish with a orbital and its still yellowy/foggy which im pretty sure its all in the inside now. i dont want to sand the lights down just incase i ruin it so ill just get a professional to open it up and clean the insides.
any further recommendations ?
Gentlemen,
Be warned - polishishing headlights with some of the above mentioned products is doing more damage than good. A new light has a sealer that stops it from yellowing under sun exposure. You need to use a product that replaces the sealer after you polish. this way your not redoing the job every 3 months and doing more damage.
One word "Glassylite"
google it / ebay it / flickr it / youtube it.
Edited by R34GT-T
i always wax my headlights after a polish, with OCW. Has UV(b?) filters/blockers, etc... my headlights have held up fine 8 months after their last polish. But it's inevitable that they'll revert at some stage, but a 5 minute job with the RO, plus Edge green on with IP 3.01 and we're laughing again. This $100 dismantling job is a bit of a rip-off IMO
  • 3 months later...
Hey guys thought this thread might help me fix my cloudy drivers side headlight. So I bought myself some plasticX and although I removed what I could from the outside the headlight is still cloudy! Further investigation revealed that the plastic mounts on the housing have cracked and now have left a nice hole... So I am convinced that I need to clean the inside of the headlight and patch the hole. However no one has advised how to attempt this. There has been mention of removing the headlight and placing it in the oven and heating it until it is soft enough to separate, but no positive statement that anyone has done this. So my questions are:
1) How do I SAFELY open the headlight
2) Should I use plasticX on the inside or just a car wash and let it dry?
3) How to reseal the headlight.. Basically can I just reheat it until it is soft and sticky again and then clamp it shut and cool?
Cheers dudes and dudettes
Edited by chrisR34GTT
After polishing with Meguiars Plastx I always put a coating of PLEXUS on the headlights and even tail lights
http://www.plexusplasticcleaner.com/plexus.html
http://www.whitworths.com.au/main_itemdeta...tAbsolutePage=2
  • 1 month later...
I just got that Glassylite product off ebay (about $40) it comes as a kit incl. 2 different wet sand papers, a polish and the all-important sealant that's supposed to stop the issue from reoccurring... gonna try it today. Will let you know how it turns out. I have the same sort of crap like llama_au above, it looks more like stress fractures than oxidation.
Mine have actually looked pretty good since the last time I hit them with PlastX which would have been a good four months ago or so. Maybe just takes repeated use and a lot of extra force. I'm pretty weak.
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
