It appears that Haltech is pretty lucky to get a replacement engine:
Nissan will continue its history of refusing to offer crate engines and gearboxes to all but a few select Nissan dealerships.
Nissan has explained that the parts withheld are “highly engineered, using technologies unique to Nissan”. So, it reasons, who receives them should be closely controlled to protect Nissan’s intellectual property.
Source
  • Replies 99
give me a break. as if you couldn't buy an r35 half cut if you wanted to. hell someone in oz already has one.
I really don't get all the fuss in this thread. These guys pushed the engine and have a rebuild coming. I did 4 motors last year and don't push them half as hard as these guys have. Good luck to them for putting their money out to develop their product like this.
I understand pretty every race r35 is Oz is running a haltec, so all of the jealous kids might as well pipe down. I don't see anyone chucking a rebadged link into them. All the best with the development, I hope you have more good results to share
Source
Yeah, this is what some people in the US are finding out at the moment-
Personally if I buy a car its on the basis that the manufacturer will just sell me the parts to fix it myself if needed... I mean for f*cks sake just looking at most of those parts listed theres only a couple I'd think twice about DIY (like the engine) because the rest is pretty much plug and play.
What a crock of shit
Two things-
1. The 'engine' restriction doesn't seem to mention cylinder heads. hmmm...
2. Why the hell is Nissan U.S HQ in Nashville? "Gosh darn Dolly, this 'ere Nee-san dun feel nuthing like ma ol' F-150 pickup..."
sounds like your taking a shot at dirtgarage/ray hall? have they been hanging shit on haltec or something?
forgive me for not keeping up with all the drama, and no, i havent read very much of this thread.
Nissan was much cooler when they were losing money hand-over-fist, it has to be said :)
I blame their being shacked-up with the snooty French.
Yeah Nissan's 90s jdm car range was quite incredible!
But nissan would be no more without carlos/renault and without adapting to recent market changes.
I dont like that they arent making the range of 'sports' cars they were, but atleast they have put all their marbles in with the R35.. And it payed off :P
That document looks like a nightmare for the privateer
  • 5 months later...
  • 3 weeks later...
  • 3 weeks later...
A couple of questions if anyone knows the answers, it would be most appreciated.
1. How much kw at the wheels was this car running over stock when it blew up?
2. How much would it cost to rebuild the car after suc a failure?
thanks
1. Approximately 400kW @ wheels I believe.
2. Including labour probably about the same money as a used stock R34 GT-R
It depends on if you can score access to the parts or not. Yes if you must buy a whole Engine Assy it is expensive. Nissan are becoming more open to selling bare blocks however and the price is much more reasonable if you buy one and put aftermarket pistons and rods in.
All depends on what was damaged in the engine failure but yes it can add up very quickly...
500+ hp with mid-pipe and new Map is plenty.. :P ...no need to squeeze an already highly tuned motor
for more....... :D
Seems like that grass is still greener on the other side of that fence.....
It's funny how once you get to the other side and take a glance back at your old grass, sometimes it looks better than the stuff you just hopped to :D
Newfound appreciation for old grass!
As a statistics nut I have to side with the people who say it's just one (possible two or three) engine out of however many there are. This said, engines are produced with as much control over variance as possible (despite minute differences between even two of the exact same engine) - so it is still a good representation of an approximate limitation for the engine. And THAT said, given the complexity of engines, without knowing exactly what caused this it's very hard to say whether it is a factory or tuner fault. Time will tell I guess.
  • 2 months later...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
