Hey Marko I was looking at going the Tomei Expreme manifolds but my mate at HKS jumped up and down and said to stick with standards match ported and polished.
He had done alot of their top cars including their Drag 33 and said no reason whatsoever to go with anything else and why change something that works!
that is good hear + they will never warp/crack
  • Replies 286
Throttle body manifold also getting the port/polish treatment
Engine assembly room kept at constant temperature
More match port/polish
Garret hairdryers -5's and Tomei dumps
Hypetune R26 Racing Plenumn fitment
Had a few dramas with this as you can see standard throttle studs too long but all good in the end!
Cams and cam gears getting dialled in
Ok motor back in the car with uprated and modified Nismo Super Coppertwin Racing clutch good for around 580kw
Also view of Tomei dumps and head oil return.
More later..........
What do the guys at HKS think of you using other Brands eg the Tomei Dumps and things like that.
I cant wait to see this car tearing up our tracks :down:
further to that - what opinion do hks have about garrett turbo's? would be good to hear feedback straight from the horses mouth
btw i also run garrett turbo's
Well every time it came down to choice of parts they would say to me .."well HKS make this part but if it was my car I'd recomend using this brand..e.g Tomei etc.
They didnt hold back on advising me what was best to use, absolutely no push to use HKS, only to use what they thought was best for the job !!
I cant wait to see this car tearing up our tracks :)
Love all the pics mate. That is one of the dream set ups I would love to have in my car, one day maybe :O Hopefully we'll see it out and about on the Gold Coast shortly.
Me too fellas, its been a long, long wait ! ..hopefully sometime in August it will all be complied and registered...
Marko they hadnt done many setups using the Garretts . They were surprised to compare the -5's to the Hks 2530's on similar setup engine dyno graphs. Garrett -5's was holding peak power for a little longer than the 2530's.
And hi octane sump extension and hypertune plenum? do they like the aussie stuff?
lookin good tho Mark! not long away now!
Hey mate hows things??
Cars all finished (well this stage) and hopefully not far off from hitting aussies shores.
I'll probably cop a bit of flack here but they definitely were impressed with the Aussie gear and pricing but...there were a few little things in finish quality that would stop them selling in Japan.
Had to do a bit of grinding to get the sump to sit up flush and had a few leaks on the welding but we sorted that all.
The plenumn...they kept stressing about the alloy being to thin and would bulge or deform but once it was on that was thrown out the door. They are quite thinner than Jun plenumn. Also the standard stud mounts were too long and they thought should have been addressed with the plenumn build.
Thing is in Japan, when your a customer and you buy a part form say Jun, Trust, HKS, Tomei, Nismo or any of the big manufacturers, you are buying something that should fit first time and with no mods. Thats the service the japanese expect !!
I think with a few of the small problems addressed the Aussie gear definitely has a right to be in the market with the big guns.
While you are at it ask them about Hypertune plenum vs Nismo?
Mike this will open up a can of worms but we built this engine keeping in mind that it was being built for power and performance but also that at latter stage I might want to go for more grunt. Right now its tuned at bit over a lazy 440kw (600ps) and with right fuel setup and turbo/ s it was built to cope for around 580kw (800+ps)
Anyway the original call was to use Endless plenumn http://www.endless-r.co.jp/pe-ji/orijinaru.htm (scroll down)
but with the Aussie dollar impersonating the peso and talking to a few crew that were using the Hypertune plenumn it made sense and finacially to go with that. Havent looked back as they reckon its super high quality and the response is awesome, the only hiccup was the dramas with mounting.
The Nismo plenumn was never on the drawing board but it would have been easier to use as with the Hypertune we had to cut a hole into the wheel fender for the plenumn piping. (Pics to come)
I think for what your going for Mike, the Nismo will be fine. You got to remember the headwork done to my motor was pretty nuts as it got the full treatment from Naprec and then the HKS GTR meisters went to work on it.
Hope that all makes sense fellas!!
FREAKIN AWESOME BUILD! Really appreciate you sharing your photos with us, but i just have one request, are you able to organise them into an order which is closer to the actual build process? Sorry, i dont mean to complain but it seems as if the photos are all over the place. Maybe its just me!
in reference to the quote below, (my quote button doesnt seem to be working)
"The plenumn...they kept stressing about the alloy being to thin and would bulge or deform but once it was on that was thrown out the door. They are quite thinner than Jun plenumn. Also the standard stud mounts were too long and they thought should have been addressed with the plenumn build."
They are absolutely right. I have seen the one on Godzillas drag car and it has bulged/ballooned way out of shape. This may well be because of the amount of boost that is run. not to say that the hypertune is a bad product but i guess thats probably why jun/endless etc charge what they charge.
Keep the pics coming!
Yeah I know what you mean with the pics but the ones I'm posting up are ones taken and sorted by HKS themselves and theres a few hundred of the buggers so trying to put them in some sort of order. I'm posting them up in the order they were given to me.
The main bulk of previous pics were mine and tried to do them in order of the build. When I get time I'll go through them again and see if I can sort them a bit better.
With the plenum, what I was told normal boost up to 2bar is supposed to be no problems at all.
I cant remember exactly how much but Godzillas is way more than that.
power to the garretts!
Cheers for the reply I really do think the jury is out on aftermarket plenums. Interesting info none the less!
Once again, great build, credit to you.
While Quality is up there at least the Jap stuff fits, Eg the Hypertune Plenum above and the High Octane Sump that leaks.
I would be Pissed if I spent 3k on a plenum and it didnt fit straight on.
i agree - i guess not all aust made bits are at the same caliber as jap stuff
Yes, although the design of the hi octane sump is good, it really is very poorly finished. Casting is VERY rough and like you say a lot of them leaked in the beginning. I suppose attention to detail is what makes Japanese products eye candy to us all. Having said that, not all Japanese products are as well developed as some found in the States and here in Oz.
Edited by AtomicBomberMan
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
