Spare tyre, you need it. I'd get rid of the amp and all wiring there just in case and as for the battery tray, make it look as nice as possible :)
spare tyre i have been told u dont need, but i have chucked mine in every time, im sure someone could lend ya a space saver, dont think anyone actually ever uses theirs lol.
and rear brake light? i got a stealth spoiler hence no brake light as i would have if i had my series 2 spoiler on. would i need one? also, my in cabin boot release dont seem to work anymore, would that be a problem?
like others have said i think, u do need an eye level one, just a rear window brake light from any auto place will do.
i thought you would need a brake light. as for child restraint, i need to source one as i removed mine and cant locate it anymore. wasnt it just one metal bracket or was it two metal brackets?
ovrtym33
were you in the inspection bay with the inspector or were you sitting in a waiting room? was this recent or a while back?
i went through without child restraints and didnt get picked up as i did like urs, took them out and couldnt find them. i think they usually only look for them for compliance, not something they look for with roadworthy.
btw im not reccomending anyone to go to regency without this stuff, just telling u my experiences with how they have picked on them.
not 100% sure about the 2" thing, i know that used to be the law, but im pretty sure these days it runs on overall rolling diametre, but not many cops really know about it (bit like most defect laws really). would be worth calling regency about that one.
Yeah, it was the law for years, but who knows how tough they are these days? I passed with a rim which was 2" bigger than what was on the tyre placard through Regency about a year or so ago.
i think you don't need to have a space saver but if you do it must have the reccomended top speed
Yes if you have a space saver, 80km/h MUST be written on it - texta, sticker, anything.
I'm not 100% sure on that Dan but I do know that I passed Regency twice with my cooler left on. It's got Earls fittings... so long as everything is routed/fitted nicely I beleive they are fine with it
Since Regency checks the numbers on the turbo housing, is it still possible to get stock r32 gtr turbos new, or any turbos made by other companies that would have the matching numbers on the turbo housing as the stock r32 turbos?
Are space savers only the yellow one? I got a black spare wheel that seems to just say "temporary use only" and "inflate to yadida amount of kPa(60psi)"... its alot skinnier than a standard wheel but not as skinny/small as those yellow space savers I've seen... so it doesnt need the "max speed of 80km/h" does it?
Space savers can be red or yellow... you'll see if it's a space saver if the tyre is very, very skinny!
Pretty sure most Skylines have space savers (or you might have a full tyre?)
They don't care about the tread or anything on the space saver... it just needs the 80km/h max written on it, as my space saver looks like it's been in the car for the lifetime of it lol...
Just as a precaution Vu, just whip out the tipex, or something white (even cream lol) and write 80k/h max on it. You'd hate to only get failed for that one thing!!
Folks, I've just rang Regency and spoke to an inspector regarding Window Tint and whats legal:
No tint on the front windscreen (except up the very top... but don't bother if it hasn't come from factory).
75% light transmission on the driver and front passenger side windows and the rear windscreen
35% light transmission on the windows behind the driver and front passenger (those little triangle ones)
Cheers
lol, nah... get/borrow a 2nd hand one...
Cheers
guess im going to be removing my window tint. but before i do, does anyone have a device that measure the percentage or should i just go back to my tint installer?
do wat i did. just take it out. you dont have to have one in there. if you take it out its just something less they can whinge about
can you turn the turbo timer off?
if you can, turn it off and leave the key in there without the remote... obviously leave your alarm off during the inspection and it shouldn't be a problem.
they cant pick on remote start if they don't know it has one...
but can they just look up the alarm specs and do you purely on that basis?
my remote start has to be activated using the remote before i turn off the engine otherwise it just turns off normally.
helso, whats a key fob? what i intending to do was to through without the remote alarm, saying i lost it. leaving just the unit in the car and its associated wiring.
Edited by Nozila
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
