Hey guys,
I have tried a seach...
But what I'm after is some advice...
Im looking at getting either Tein flex or the cusco zero 2's
Has anyone had any experience with these 2 coilovers? pro's and con's?
What are they like for track use?
Currently I have bilsteins shocks, whiteline springs - these are a good package for street, but as the car is being used more
and more for track use, Im looking to get either one of these two.
Or is there any others I should look at besides these 2 types?
Are the ISC/d2/g4 coilovers any good for track work?
Cheers,
Chris
https://www.sau.com.au/forums/topic/248405-coilover-upgrades/
Hey guys,
Cheers,
Chris
Hey,
havent had those 2 brands before but I have BuddyClub, they squeek a little and they're a little expensive but they are good, and are really stiff in the back end.... I dont know where you are, but there is a place in QLD that sells pretty good brands like that its called 999automotive its in beaudesert. There are so many brands to choose from when it comes to suspension.. its a painful decision :D have fun.
Ashleigh
Cusco zero 2's are not that flash and sure as hell not worth the money they ask for them. The Teins seem to be a pretty safe bet, all roudn flexible and good quality shock.
I was in a similar position regardign a change from Whiteline street package and going to the Teins. I went Teins as thats what is better supported in club car circles down here in Vic. With Heasmans and Bilsteins beign so well supported in NSW then i atrip to them to get your current Bilsteins tweaked or up spec'd should be seriously considered.
i'v got the tein super streets which are excellent for mostly street with light track work. however additional sway bars do harden the ride and make them an excellent track option.
i know people with the flex's and they are a better track setup for our cars. theyre a lot harder. better for track not so good for street.
ISC N1's are a fantastic coilover for the money. If you have any questions feel free to send me a pm/email etc. If you have a big budget we also sell DMS coilovers for $3000+.
Thanks,Ryan
Edited by ISC-Performance
Because a spring is a spring is a spring...within reason. So changing the spring rate isnt address the whole situation. Provied the shocks all come out and the increased spring rate is accompanied by a change to the shock valving then i am confident the Bridgestones would be great. Being in Sydney i think this is your best option.
I personally use the TEIN super streets and they are a good comprimise for ride comfort / street use and some track use, they're a bit too soft if youre looking to pick up every split second possible on the track though.
A good mate of mine uses HSD-HR's and they are awesome value for money (he's a whole second quicker around Wakefield with less power than me), they're really stiff though so not good for street use.
Have a look at - http://www.otomoto.com.au/ for prices on HSD's :D
Sorry I should have made myself clearer.
When I changed from a Whiteline spring to an Eibach I changed the spring rate because the Whitelines were too soft for track work. The upside is that the Eibach spring is a lighter spring than the Whiteline - about 4 kg between the four - this despite having a higher rate. Also you can select from a wide range of rates whereas with the Whiteline you are stuck with one.
You can revalve the Bilsteins if you want/need to. SK didn't recommend doing so going from a SK/Whiteline package to a 5kg front /4kg rear on an R32 Gt-R.
So you MAY find it possible to change to a harder Eibach spring & keep your (unmodified) dampers for quite a bit less money than shelling out for a Tein or similar package.
Edited by djr81
Thanks for all the replies guys, its certainly alot to think about!!
Just throwing this one out there....
The D2, G4 and ISC type coilovers - how would these compare with just the tein super streets?
Or would these be pretty much similar?
Just throwing it out there for a bit of discussion!
I'm not so sure about the ISC, but the D2 and G4 are very stiff, my personal choice would be the Super Street.
i ran d2 in my r33 (track-spec ones);
the only thing i have them to compare to are my current setup tein type RS; and as you can guess the tein are miles ahead of the d2 in everyway.
having said that i found the d2 to be a good entry level coilover for the track (i did drift and few mc days) but they very bumpy on the street, i find the type rs to be less bumpy then the d2 (if i remember right my d2 had some crazy spring rate like 14/16)
Love my Tein Type Flex. Changed spring rates and valving (all done by Fulcrum on the chassis dyno) and believe that I now have the ultimate ride for street. If I need to adjust for track work the EDFC has plenty of adjustability in it.
Either of your selections would be good.
cheers
the tein super streets will be a downgrade from what you have. they are the cheapest entry level teins are a twin tube shock about on par with the factroy GTST gear. the bilsteins you already have are mono-tube just not adjustable.
I wouldn't bother 'upgrading' to anything less than tein MONO-flex as at least they are mono-tube. but if you really want something better look towards some tein type RS or type RA. they are monotube, circuit oriented suspension, and have all alloy damper body, lots of height adjustment and the valving and springs are chosen and set-up with circuit use in mind. unlike the mono-flex which are more street oriented. be careful with flex vs mono-flex too. the old flex were twin tube, then they had mono-flex, but I believe the new flex are mono-tube, but it would pay to make sure of what you're getting.
imo D2, G4, HSD, ISC etc are a waste of time. I've never driven a car with a set that I thought was that good. and they will certainly be a step backwards from what you have now. and yes I even have a set in one of my cars (silvia). I forget which type though, i think HSD.
the other good options out there are some good ohlins dampers which are quite cheap out of japan. and if you are buying springs seperately look at some swift springs. they are japanese, and good gear and not too expensive either.
now that the AUD is so weak against the yen and USD it may be worth looking at local options which are now competetive on price. maybe talk to murray coote (he does pro-flex gear) who makes very good gear, or jamie drummond (DMS) also good stuff and has some more affordable options than the coote stuff. they both make shocks for lots of top cars in all types of aus motorsport.
not big fan of coil overs to bumpy
Usually not an issue on the track, unless you are off the track and in the dirt.
Chubbeh... I suggest you get Tein, simply because they are Jap-spec and green. Everyone knows green jap-spec coilovers are ftw lol
On a serious note, if and when you get new coilovers, let me know. I might know someone interested in putting them in another boat :P
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
