Has it got the sequential box back in it?
RH9? There's enough power to run a 7 :thumbsup:
What box is in it, Paul? And will it be running in the fastest street car comp at WSID next month? :D
i asked that question 5 pages ago :)
Edited by TiTAN
  • Replies 126
Posted Images
Went down to JEM last night, and found out they used Adams Mainline for the AutoSalon.
What was it that gave it away? The big JEM stickers on the dyno or the big ones on the control unit in all the photos and video from the event?
(Apologies if you didn't attend the event - it just read like you had been super-sleuthing.) :(
LOL!
First of all i would like to say well done to all involved 1250hp is very impresive.
What would be the cost involved in building a engine like this complete with turbos etc?
1 very hot wife,
1 small child
Left arm
Right leg
And a patridge in a pear tree!
$60k would do it I should think. How many would you like?
60k thats a bargain to make an extra 200hp atw compared to when it had the crd 2.7 in it.
since the 2.7 is tired and no longer of use i would be interested in purchasing it so please if its for sale shoot me a pm
thanx Paul
probably due to the fact it mite be running some 15" drag rims and a parachute now? :banana:
So when is this bad boy going to hit the strip? And on that topic, why on earth has GAS2JZ not hit the 1/4 mile either? That would be fricken cool to see :angry:
rh9 will be hitting the track in jan 09 with drag radials...
it will not be running the nitrous for the drags.. and about 1000hp at the wheels...
we will seee if the gearbox is up to the job...ha ha..
cheers, mark
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
