i was just looking through this thread and saw the discussion about lammy426's power figures. you have to remember he is in england, and it's winter over there, so nice chilly air temps which will give much better power. if he was to bring it to australia and run it on a 30 degree day it would ping it's arse off and he would be making much less power. also lammy, you say "at the hubs" does that mean you are using a hub dyno? if so, they are known to give different results to wheel dynos
this one was done in winter but it was in a heated workshop,hub dyno's are more accurate than a wheel dyno ,and don't forget tiger white still as 10whp more than me but i don't know if theres much temp difference from aus to nz,anyway i still have a few bits to do so i might crack his record out of an rb25de+t
hub dynos might be more accurate than wheel dynos, but they often give totally different results. basically my point is, unless the 2 cars are run on the same dyno on the same day and tied down the same, you can't really compare them.
very true ,but i do look at gtst's dyno'd on the same one as mine,the one i have talked to at .85 bar only get around 280bhp ish ath. i've set my goal at 345+ same as tiger white, i don't know if i should get a topmount or a hybrid turbo my tuner said he can get more more power with a bigger wastegate because its creating heat what do you think, oh and he loves driving my car because theres no turbo lag and it'll outdo a gtst with more bhp,not top speed of course as i still have the 4.3 diff in
  • 1 month later...
my hiflo stocker arrived i'm going to alter the wastegate and actuator abit before i fit it
all done and dyno'd,now we have 395bhp ath at 15.3 psi,i nearly fell over when he told me ,well pleased
lets see how long it takes for it to blow up lol.
Whatd u do to it and how much mulaa did u have to throw at it? :rofl:
just made the wastegate bigger and fitted a collins 12 psi adjustable actuator,my tuner was just concerned about the hg blowing,what is mulaa
mulaa (moola) = money lol.
Turbo? internals? intake plenum?. You basically bolted on some parts and made close to 400hp?! :rofl:
this is what i've done over 4 years http://www.skylineowners.com/forum/showthread.php?t=142304 and with buying the car completely standard for £1905 and the mods have cost about £4000 with mapping
Hey all Thought I would post up mine as I got the car back from unigroup today.. A few little problems holding me back on power but should be an easy fix.
Model - R34 25GT
Engine - RB25DE
Modifications / Parts Used - R34 stock Turbo, Injectors, Manifold, 3 inch Dump/front pipe, Kakimoto Full Mega N1 exhaust, Walbro fuel pump
Engine Management Used - Power Fc with hand controller for R34 Neo
Fuel Used - BP Ultimate 98
Boost Used - 7 PSI
Dyno Tune Results - 160.5 KW at 6500 RPM
Misc- Went with the Power FC for the complete solution although there are a few problems that need to be sorted out. Like blocking the signal that looks for the TCS and sorting out how to operate the Solenoid that controls the valve in the Inlet manifold (if anyone knows a way to do this please let me know)
Costs - Parts: Aprox $2500, Labour: Free as I did all the work myself :blink: and Tune: $750
Allover things went really well.. A few unexpected problems, My VCT is switched off atm as its not getting a consistent amount of voltage so thats killing some power, Boost controller needs to get pulled apart to see what the problem is with it not sending the signal to the solenoid.. The only other real problem is the Valve solenoid thing in the throttle body/manifold, Have stuck it in the Top end range so its always open which is killing some of the low down power.. Having replaced the Stock ECU there is no signal to control it as its not on the GTT model.. If anyone else has had this problem before and found a way to solve it please let me know or if anyone can suggest some ways to control it im all ears.
Once these few problems are sorted It will push out an easy 180+ with real good torque (dont have the exact specs as its not tuned.)
Model - R34 25GT
Engine - RB25DE
Boost Used - 7 PSI
Cara (MissR34) may be able to help with the variable length manifold solenoid that you speak of... reason I suspect so is because she is running a PowerFC on her R34 RB25DE NEO.
Sounds good so far :sick: did your power curve taper off after 5500 RPM or is the power at 6500RPM your peak power? Well done doing all the work yourself, saves a hell of a lot in labour costs! Got pics of the engine bay?
I'll eventually get around to getting another power run done. There's been GReddy EBC, Gearbox Rebuild and Catback Upgrade since the last power run so hopefully should see some improvement.
Sounds good so far :yes: did your power curve taper off after 5500 RPM or is the power at 6500RPM your peak power? Well done doing all the work yourself, saves a hell of a lot in labour costs! Got pics of the engine bay?
I will have to check that out thanks N-dawg.
Peak power is at 6100rpm then tapers off to about 140kw at about 7000. Ill attach the dyno sheet so u can check it out.
I have a pic somewhere of the engine somewhere, just looks stock with all the stock piping etc.. just had to add a bit of 2.5" piping to reach the elbow onto the throttle body.
I managed to fix the boost controller today which is good.. the vaccum hose had been pulled off the part inside the boost controller itself, just loosened the clamp holding it on slid it back and redid the clamps.. Yay for easy fixes :) EBC is a Blitz Dual SBC with 4 presets.. I should set them to 8-9-10-11 haha stupid stock turbo, need to get a GT-RS i thinks..
VCT will be getting fixed on the 18th when it goes back for a retune and up the boost..
Any reason for running that boost level? Did you try more boost to see what the result would be?
Yeah the EBC was playing up and we couldnt figure it out so we could only use standard actuator pressure.. Gonna bump it up to 10 psi now that I fixed it then when the VCT is fixed up it will get a final tune. Will be looking at 180+ Ill get a torque curve as well to show.. Should be very fun at next Texi.. shame its soo far away..
Heres my long awaited (almost) finished product:
post-36975-1273579588_thumb.jpg + post-36975-1273579744_thumb.jpg = post-36975-1273579805_thumb.jpg =
and good times :thumbsup:
We actually got it 5kw shy of 300 but wanted to make it safe as possible: @18psi this has a max knock of 20 which is nothing
nice wastegate,good work,whats 283kw in bhp and is that with standard rb25de internals and head gasket,thanks john
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
