Thought I would throw up a few pics of my completed SR20 build - no dyno yet (finished at midnight last night).
Interesting bits:
Full-Race Twin Scroll mani with twin gates
3071 with .78 divided ex housing
Hypertune Intake
1000 cc Sards
Autronic
Forged and Darton Sleeved Bottom End
JHH Engineering Head with larger Super Tech inconel ex valves
Tomie 260/260 12mm lift pro cams
Pic of the gates before the dump tube went on - these actually merge back into the main exhaust.
Edited by juggernaut1
https://www.sau.com.au/forums/topic/249832-my-sr20-build-pics-inside/
  • Replies 81
Damn sweet looking setup. Cant wait to see a power figure. As much as im enjoying my 26 i miss my SR's...
Why the twin gates?
The manifold and turbo exhaust housing is divided (i.e. twin scroll). On a SR20 this means cylinder exhaust manifold runners 1 and 4 are paired off and completely and separately to 3 and 4 right up to the exhaust wheel.
Because they are paired off each pair of cylinder runners has its on gate. Whilst it is possible to use a twin gate tubes merge into a single gate - there is a cetain amount of exhaust gas pressure leakage from one gate tube to another in the exhaust manifold as it is not possible to create a perfect seal between the two gate tubes at the merge point just before entry into the single gate.
with a setup that well designed for boost control, I would have thought you would have optioned for at least a GT3076 (6 blade version) ?? Not knocking it, but that turbo will produce sub 300rwkw outputs, but a good mid range.
Just think thats a bit of an overkill for hte powerlevel you are going to achieve.
Well done none the less, don't take my comments as slander, just more curiosity.
Jono
Edited by The Mafia
Jono
No offense taken. I actually did consider the 3076 but Geoff Raicer from Full-Race convinced me otherwise and advised me this setup will acheive quicker lap times on a short circuit like Barbagello in Perth where I live. I seemed to get the impression from him that the slight loss in transient response wasn't worth the extra hp gain the 3076 would give.
In any case, I wasn't chasing any certain power level more a case of the best transient response and area under the curve.
awesome setup, good components with a well thought out plan ad application. So often i get cars dropped off that are based on the hp rating of the turbo and not the application.
We did a S15 earlier this year to achieve similar things (you probably know athid) decent plenum, decent turbo setup, cooler ecu etc and well it produced the craziest curve and torque i have ever seen outta a SR20, i cant wait to see your dyno grpah as im sure they will be very close.
here is athids;
Edited by URAS
Yes Trent it will be interesting to see how it compares to the single scroll stuff. Can't wait to get it on a dyno, tune and run it in.
i reckon your a winner for sure, beau's setup on the beams engine sure aint a slouch :P
  • 2 months later...
Quick update
Had the car on the dyno yesterday.......ambient temp was 43 degrees and high humidity here in Perth so it was working hard......anyway at 17 psi the Hypertune intake manifold split open.
Couldn't see it (or hear it) at first but couldn't get the car to idle at less than 3000rpm so we new we had a leak after the throttle body as we checked all hoses etc.
Pulled it off last night and the intake had gashed open where the idle control valve outlet is (which is underneath the manifold). Would have thought these manifolds could have handled alot more boost.
Anyway will weld it up and put it back on the dyno..........with more boost.......hopefully.
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
