i don't think he would have had webber. and I don't think he backed off either. if anything he was going faster after the thinly veiled order to ease up. he just ran out of laps.
  • Replies 2.5k
Posted Images
maybe they should hold 1 short race a season (no fuel stop, one set of option tyres) as a demo where all the drivers drive exactly the same car, including suspension and alignment settings (some sort of f1 'control' car), and ballast them up so the weights are a dead match, and then we really seperate the men from the boys :)
shame it'll never happen...
They've kind of done something similar with charity go kart events in Europe. Not sure if they still do them but the one I saw in the early 00's had Michael Schumacher out front closely followed by Jarno Trulli with a 2-3 Kart gap to the rest of the drivers.
FIA 2010 Formula One entry list:
SCUDERIA FERRARI MARLBORO - Ferrari
SCUDERIA TORO ROSSO - STR TBA
RED BULL RACING - RBR Renault
AT&T WILLIAMS - Williams Toyota
FORCE INDIA F1 TEAM - Force India Mercedes
CAMPOS GRAND PRIX - Campos Cosworth
MANOR GRAND PRIX - Manor Cosworth
TEAM US F1 - Team US F1 Cosworth
VODAFONE McLAREN MERCEDES * - McLaren Mercedes
BMW SAUBER F1 TEAM * - BMW Sauber
RENAULT F1 TEAM * - Renault
PANASONIC TOYOTA RACING * - Toyota
BRAWN GP FORMULA ONE TEAM * - Brawn TBA
* Conditional entries
Both Ferrari and Red Bull say they entries are conditional but FIA thinks other wise???
FOTA have said Fu(k you bernie, we're outta here.
http://www.theage.com.au/articles/2009/06/...4918172451.html
This will be interesting, from what i have been hearing the group that runs MotoGP have been talking and are ready to run a series with the breakaway teams.
if the teams all pull out and make their own championship. All burnie will be left with is the F1 name and logo....and Williams.
Burnie isn't rolling in money for no reason, he'd be stupid to let 90% of the field make a brake away series.
nicee i been wanting this to happen
With those teams gone from F1 i guarantee the new breakaway will be much more exciting.
I bet the F1 under max will be similiar to A1 GP.
Just hope channel ten or HD one will get the coverage for next year.
Imagine the lineup of cars in the new championship
Im pretty sure you will see other teams entering, hoping nissan enter :down::P
would be quite amazing if they get a good line up in the break away.
Im pretty sure you will see other teams entering, hoping nissan enter :P:)
If it does go ahead (it won't) it will, like every break away series that has ever been, result in a divisive, weakened pair of second rate "championships".
What will happen is that a compromise will be reached. I just hope that Williams & Force India screwed the FIA for all they are worth before they signed on.
As for Nissan - it will never happen. Renault owns Nissan & Renault can barely afford to be in F1. The expectation is that one or more of the manufacturers will be gone at years end. There is a lot of money on that manufacturer being Renault. Toyota is prbably close to leaving too - too much money for no results. They should go back to rallying (just without the cheating). :down:
Edited by djr81
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
