How does a combo like that go on the street, response and driveability wise (T88) ?
I'm pushing 330kw Atm and have turned into a bit of a power whore.. Lol
So im considering going the t88 route with one of the smaller rears, any advice ?
Cheers,
Mitch.
On the street, can't be good.
Considering nothing really happens until 150km/h, doesn't really suit a street driven purpose - if you want a fast streeter.
If you take off in 3rd, maybe...
Oh come on, a 400rwkw+ setup being fast on the street?
Please... a 330-350rwkw setup will always be the more streetable setup in the hills and so on.
The bigger power setup will "feel" faster, because its nothing nothing nothing - boom - there we go...
Feeling and actually being fast = not the same.
Completely and utterly disagree - by far the fastest street car I have ever been in was making around 480awkw when I went in it. Not just top speed stuff, just everywhere. RB30DET running 1.8bar with a hearty turbo etc... in an R33 GTR. Nuts, at any speed. I liked :P
I'm sort of tossing up between 34 N1, GT-RS and T88,
Obviously im a fan of twins :P who isnt :( ?
But im willing to go big single if it will push me into the 450awkw area....
Say if the T88 will give boost by 5, so i can rev it out to 8 or 9k, thats not such a bad powerband, especially considering all the power you pick up right ?
Cheers,
Mitch.
Nee-san - im assuming yoiu have R34 N1s/GT-SS's/-7s or -9s currently???
On a properly built motor you can get around 400rwkw from lowmounts, just the usual Garrett -5's which would just be a bolt on/off affair for you.
Probably the best of both worlds from the sound of your posts.
We are talking 2.6ltr's far as i know as it sounds like Nee-san does not have a stroker/3ltr setup currently :(
I'd agree different motors/setups could be better depending, just not in this particular case.
Steve I did just find this thread LOL :P and all i will say is this...
If i ever lose to a low mount gtr on the street i would set fire to my GTR!!!
If your interest is in hill climbs etc etc you like response stick with your boring low mounts...
R31Nismoid what are you going about?? How isn't a 400+ kw gtr not fast on the street??
I got friends who love low mounts etc etc and they dont stand a chance.....
Cheers,
Mitch.
Well I run a TRUST 6 SPEED DOG box which is a close ratio gearbox.
Car drives really well and isn't sluggish at all,Driving a single turbo gtr is the best feeling. I will never go back to twins!
If you do decide to go ahead with a t88. there are so many options you can use. T88-33D (15cm/18cm), T88-34D (15cm/18cm/22cm)
I got got like two kits here i am not using atm so if you want one let me know.
R31...you said that nothing really happens until 150km/h with the T88. I completely disagree, and hence my post. Once its on boost its on for young and old...
if you want to look at it that way, nothing happens untill 4000 where it starts to build boost, you hit full boost at 5500 and then its wheel spin for the first 4 gears.
Hey Guys, Bit of a can of worms this one !
R31Nismoid, I have 33 N1's at the moment on a 2.7 litre overbore, i do love the idea of -5's as alot of the boys on here have some very impressive results however i might be looking for a touch more power then what they will put out.
T88 ON BOARD, do you find that the close ration really wakes the car up, or would it be ok on the standard ratio/box ?
As for that video, that 34 R is a f**king animal ! is that your beasty is it ?
Thanks for all the input boys !
Cheers,
Mitch.
Cheers,
Mitch.
Nah not my car just thought of that vid and shared :P My beast is asleep atm resting up haha!! But it drives like that...
The close ratio box is the best thing for it it is so alive and responsive, eg. When im cruising in 3rd and put my foot down it will want to come on boost straight away.
I have the standard 5 speed currently in it and it has become alittle sluggish longer ratio's but its not so bad..just annoying for me as im used to the dogbox i run. If i was to run a standard 5speed ratio dogbox (ppg) i would put GTS-4 diff gears in which would be fun :(
Mitch End of the day your at limits with lowmounts if your chasing power! and a faster car...Single or Twin Highmounts is what you need if you are serious for power.
I have the standard 5 speed currently in it and it has become alittle sluggish longer ratio's but its not so bad..just annoying for me as im used to the dogbox i run. If i was to run a standard 5speed ratio dogbox (ppg) i would put GTS-4 diff gears in which would be fun :P
You speaketh the truth :D
I suppose ill have to pull my finger out and start getting shit done on my little 4wd datto ;)
Cheers gentlemen,
Mitch.
I guess that means "something" is happening then... (be it actually useful or not i don't know)... my bad :P
Cheers,
Mitch.
Just a bit of discussion - hardly a can. If you want a can of worms... ask about what cams to use for 380rwkw lol :P
Ok so it is a stroker... getting there with the info... any other hidden informationzzzz???
If you are after a tad more than it seems to be T04Z country for you, 440rwkw easily enough :D
Do you have the larger rear R33 N1's? I've never heard of the smaller R33/R32 N1's getting much over 300rwkw unless they have the Nismo rear housing or similar (ie larger).
Although i disagree with low-mounts being unable to make big power.
We've seen 440rwkw from Garrett -5's before on a super 2.9ltr, and GT-RS's will do over 400rwkw as well.
little of topic, Was wondering whats the powder loss % for 4WD to RWD, if the GTR makes 450KW at all 4 wheels whats that in rwkw,
450rwkw, its same same really.
Paul and a few others have tested it, not much of a difference with factory transfer cases.
Once you modify them it changes a bit however.
Nee-San, see if there are any built gtr's with those turbos you mentioned, in your area who have owners happy to take you for a spin
some like the rush of a single in a straight line, other like more usable power delivery for corners/hills.
It's a never ending debate, for example I tried a single, and while it was fun my car is mainly used for cornering sort of roads and the lag meant it was too slow. Switched to GTRS's and very happy, tuning hasn't finished and it's already at 400kw. Sure every now and then I have a craving for driving a single powered one (and luckily have friends that let me drive theirs), but overall very happy with the RS's as they're not too laggy (400kw @ 6000rpm), and have a nice smooth curve
there's a lot of graphs in the dyno result thread in this area, that's definatly worth a read :P
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
