Cheers for that Elite, Its pretty responsive considering the power its making and the boost its making it at, is Noels boost curve any more responsive?
Jarrod
Yes it was a little more responsive. Noel also doesn't have VCT but same engine spec basically + E85. He was making 20psi by about 3900 but with the car having dump pipe issues and not being able to control it, we've had to slow it down a little.
Once it's finished it should be more responsive than that graph up above
540rwhp at only 17psi is insane!
It's more insane how early it comes on. We are loving this new turbo. I'm putting one on pretty much everything that wants to make near 500hp. They are a lot bigger in size but just as responsive as the 35R and edit: a lot more responsive than a Z. Win win if you ask me
Anyone putting one on a stock stroke RB26 yet?
Yeah Gervase's (Strik3r) R33GTR has one.
On the dyno sheet I have for him here, he was making 1 bar at 105km/hr in 4th
Don't know the rpm though. I think is was somewhere around 3900-4000. He has a big port tomei cam head. Standard bore and stroke. Picked up about 400rpm response as opposed to the T04Z....and made a little more hp
because of the headwork there is less restriction hence 17psi is probably comparable to a bit more on a motor with a stock head.
kind of like how 5psi on a huge v8 is a big difference to a puny rb20
Edited by Rolls
Aside from pretty much a de-dag on Noels ports, the only difference is his cams at 260 x 10.25. Even the valves are standard size
What turbo are we talking about...? Is it one of the new garretts..?
Has anyone tried the new GTX4202R yet..?
There are folks in the US who have on Supras and Hondas that I have seen with gains over normal GT4202Rs. I know someone who is in the process of putting together a twin GTX4508R setup, though thats just silly.
is it some 8L v8 or something?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
