Being realistic, How much difference do you think you would see on a Rb 26 with aftermarket turbos, say 2530's?
If its anything like VCT on/off difference on a 25, then there are certainly benefits, but as with all its cost... Which certainly sounds reasonable too :D
3lt + vct... mmm let the fun continue.
We are looking into an rpm box for you guys.
have you thought about adjustable intake and exhaust? or just intake?
i assume if you did an adjustable exhaust you would require a crank trigger for timing and a computer to support it though.
Crank triggers are available easily enough from a Sydney shop, they're almost done with a version 2 which is direct plug and play for power fc. Version 1 worked well but like anything they found where improvements could be made
I can think of a certain setup it would be good on!
Huge difference. Up to 1000rpm better boost response and an extra 40 odd HP through the entire midrange
You cannot really do two due to the way it is activated and you are only increasing/decreasing overlap so having both going is pointless.
meh, the 30 is always going to make more power sub 5,000 rpm but 5,000-8,000 I reckon the 26 will make at least as much. when you're up it there's not much time spent sub 4,500 or even sub 5,000 in a GTR. if it's a track car and you take the 26 to 9,000 (which is easily done with just some valve springs really) then see how the 2 compare.
don't get me wrong. I like the 30s and they have their place. for certain applications they are better than a 26. but not in ALL applications. both engines have their ups and downs.
don't forget as well daniels engine is a fairly basic 26 build. pretty much blueprinted, N1 type engine with mild cams. I'm sure with headwork etc it could probably make even more. but shit who really needs more than 400kw atw????? it's a road car after all and a fking nice one at that. it's not just the 400kw, it's the fact it's a 1 owner since new Nur, low kms, immaculate body and interior, and all the nice bits like big Alcons front and rear, hand made midori titanium exhaust and on and on the list goes. *sigh. such a nice GTR.
we saw that comparo with rockabilly's rb30 which had 100hp more than his mates rb26 on that track yet the 26 was pulling away on the straight.
in regards to VCT - reason its not that popular (although making a lot more headway after talking to paul diemar) always comes down to bang for buck!
Crank trigger, E85, -5's, stroker and VCT. The starter motor is almost going to bring these babies on song!
HKS has a exhaust version of their Vcam. Have not seen it for sale yet. Yes it would be an improvement but would it be the significant gain like we see with the inlet?
BMW must have seen benefits to controlling both cams as they changed from single to dual vanos with the s54.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
