Nope just more boost through the mid range when I decide I wanna drag it..
But you can see it spool faster sub 4000rpm, so must be more to it than turning the max boost up, right?
Stripped the hardening of 1st, 2nd and 3rd gears, 4th and 5th are the only gears that dont whine like a biatch.
UNIGROUP are in contact with BEARS to rebuild it with a internal mod which will feed oil to the front of the box.
Hopefully get it sorted in a week or two, hopefully.
Those two runs were done one after another. Just enough time for Yavuz to set the settings for more midrange. No.come timing changes at all.
Its not the et thats important. Its the mph. Thats where launch technique, high stalls, tyres etc are (EDIT-) NOT* as important
Yes agreed. Isn't more important to have a faster car than a more powerful engine in this application. You trying to better your time. Aren't you??
Don't know I must be missing something.
Point I am trying to make is: why are people so hung up on dyno power when they don't even know how fast it is.
They go to an engine builder and say I want 450awkw. On the dyno it says 450kw' customer is happy. Guy comes out of another shop with 400kw they drag and 400kw car rips the other. Dyno is a tuning tool and it gets proven over and over again. Unreliable comparison. 1/4 mile ETs and MPH are not and really is the only measuring stick (excluding track setups of course).
Anyway, sorry for interupting. Carry on.
Haha your on Mark, they do sell those delicious donuts there at wsid...
Adam like Paul just said, those runs were one after the other and I don't believe the ramp rate was changed as I was sitting right next to him for those runs. He just played with the AVC-R boost controller to give it more boost through the mid range.
Possibly the gates are holding shut and sealing better as its not bleeding the boost off as early...
I will ask him and get back to yas on that
so this is a 2.6 with a big single? and it's the same as Paul's 2.8 with -5's?? very intrigued..... variable timing mod??
on the CAT research - looks like it will range from low $300 (venom) to just under $500 for the CES one - Ballistic is a touch under $400. These are with flanges.
CES went into some detail in their email, and said the one they'd go with would be good for 500wkw - but Ballistic has flow info with details at what pressure they did the test.
I'll see if CES has any specific flow info.... thinking Venom is out of the running now, Ballistic ones have been around longer, bit more of a known quantity and have put up flow results with specific details of how the test was conducted.
But being CES, i'm confident of a good product. See how we go...
I personally use a Venom 5inch cat 100cell and does the job at 550rwkw. Good finish and build quality, it took me a good 30mins to bash the guts out of one of them with a heavy steel bar :)
Contact George at Venom, buy cat and save money.
No vct. Remember that's loaded on a dyno. Taking off from lights there is still a noticeable difference in twist down low. We found the same thing between N1GTR's car when we both had GTRS's. Curves were almost the same, but Steve with the 3.0 smAshed me around town
Yep so single on a 2.6.. Like Paul said, right down low you can feel the torque of the 2.8 over the 2.6...
Once everything starts to happen this set up is very similar to Paul's old set up which in my opinion was still a very good -5 set up
No vct either
Simon, once the tuning for the BW was done we tried to bolt up a precision 62-64?? The dump pipe didn't quite line up due to the large frame of the BW.. Yavuz was very keen to do a back to back and he believes response would have been very similar if not better then the BW, and that the precision would have given another 30-50 rwkw up top
Must remember the bw runs a plain bearing as well
how much heavier is the 33 over mighty 32 though :)
6466 CEA.
That was hilarious. The BW was tuned less than 24 hours and here they are trying to stick another turbo onto it. If it fit I'm sure Joey would be sticking a few K into my account haha
My 32 gtr was rebuilt with the following parts and was run in and tuned by Sean at EFI Performance
Engine:
Rb26 (2.6l)
Cosworth forged pistons (87mm)
Manley conrods
R34 gtr crankshaft ( new from Nissan)
Acl race bearings
Arp rod, head, main bolts
Reimax billet oil pump gear
Tomei 1.5 mm head gasket
Kelford 282 cams
Manley valve springs with ti retainers
Sump baffles
Oil cooler
Balanced and blueprinted
Os giken twin plate button clutch rebuilt by NPC
Machine work done by chilton engineering
Engine assembled by Dan at ERD
Greddy plennum
Greddy 100mm pipe kit
100mm intercooler
Turbonetics billet gtk 1050 turbo with .86 twin scroll rear housing
Turbosmart 60mm wastegate
2.5 inch screamer pipe
6 boost exh manifold hpc coated with egt ports
4 inch dumpipe
3 inch decat pipe
3 inch TItanium cat back exhaust
Magnafuel 750 pro tuner fuel pump ( 2000hp)
Bosch 044 (lift pump)
7 litre surge tank
Fuel cooler
Aeromotive fpr
Bosch 2200 cc injectors
All braided hoses
Splitfire coil packs
Power fc dejetro
Car made 650hp at 26 psi (485kw)
I will post a pic of Dyno chart soon.
The ignition system is at limit at 26 psi
I have just finished installing ls2 truck coils and an ati balancer. Next tune the boost is being increased and rev limit is being increased.
Aiming for 700hp + on 30 psi.
Will post results when it is sorted.
Engine:
Rb26 (2.6l)
Manley conrods
Acl race bearings
Kelford 282 cams
Sump baffles
Oil cooler
Greddy plennum
100mm intercooler
4 inch dumpipe
3 inch decat pipe
7 litre surge tank
Fuel cooler
Aeromotive fpr
All braided hoses
Power fc dejetro
And I bet absolutely none of the hp produced is anything close to exciting compared to what you produced last week haha. Congratulations!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
