when i was using Caltex, they were bang on E70 the whole time (except for one batch in the dead of winter being bout E65)
which reminds me, i need to check with Caltex if they've switched to 85% - you could always buy a sensor, not run flex-fuel but just use it as a monitoring tool.
hahah, yeah that's true. just buy straight ethanol and mix yourself! :D
but for normal tunes, a variation of E% a few in either direction isn't going to make a difference. Don't think Trent has anything smaller than a 5% change resulting in any timing/fueling change on my maps
  • 5 weeks later...
The turbo is still 600hp rated though, now matter what CR you have.
The only way to make that power with a 35 frame is if it is a hybrid, like a 3566 or similar with a big A/R and judging by that dyno graph it would have to be because that is a laggy curve for a 35R on a 3L.
Even still, 500kw Thread: ACCESS DENIED.
It's a GTX53R not a normal GT35R so it does flow another 70odd hp more...
In saying that the results are a little eyebrow raising and also don't fit into this thread
Well last time you posted then 490rwkw result you only ran 136mph... :merli:
Time to go back to the strip and see if you'll actually get near 140mph, they be the results we wanna see
Either way it's not 500rwkw - so have moved the posts to the 400rwkw thread.
  • 1 month later...
car was making 431rwkw when i ran 10.8 @ 138 MPH
i have since gone to a new tuner and hence new results.
U know who micks motorsport is?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
