Also I would ask the scrutineers at the drags what you will need when you get into the 10's, if I remember right you will need to fit a tail shaft loop, I got one but never fitted it.
You can have the one I got if you want it, it will need some mods to fit but its new and to spec and has all the nuts and bolts needed, you would just need some plate for the interior side, my new project is a MX5 that I will set up for the track and it will never need it (it doesn't have the torque to pull the skin of custard).
Theres also the possibility the ATTESSA hasn't been properly bled meaning it'll be more or less RWD… Just a thought that is. I bled mine up after changing to my old twin plate and it made a world of difference.
If the gearbox has come out at any stage the ATTESSA needs to be bled
Unless its got issues thats not normally the case. Every GTR box i pulled out went back together fine, and trust me i did heaps ;)
What you can do as a cheap mod is pull the plate out of the transfer case that the line goes into. Drill and tap a hole and put a bolt in it with a locking nut on it. Spin it in a bit to preload the trasfer case. I wouldnt drive around with it locked up very tight as you will probably wear it out but it would be fine for the drags :)
As for getting your car down the dragstrip sime1, what rpm is it crossing the line at and in what gear? What 60 footer does it run and is it spinning or bogging?
I had issues trapping at much more than 128mph and did a diff gear change and now run 136mph pretty regularly. Car weighs in at 1460 and was only making 420rwkw on the Advan dyno till the turbo change.
Depending on what the cars doing there are also some very cheap mods that can be done to help traction. Some washers is all it took for me to go from wheel spinning to bogging down pretty badly. You could also ask Yavuz to set up the 2 step on the Link, from memory it is running a Link isnt it?
ATR43SS4CBB Alpha turbocharger
93 model R33 GTST Forgied CP pistons, valve springs
Stock Cams
1200cc injectors
600x300x75mm Front mounted cool
Brae high mount exhaust manifold
HPVA 50mm external gate plumbed back.
Xforce 3inch Cat back exhaust
100 Cell Cat
Profect B electric boost controller
4inch intake pipe
Adaptronic Plugin
Power 435rwkws @ 25psi , E85 Fuel
  • Like 1
Guided at 4000 / 4500 / 5000RPMs.
Per description on the boost curve sheet: 19psi @ 4079RPMs, 25psi @ 4218.
There was a split silicon hose that was unnoticed, affecting boost response. This turbocharger is going back to dyno again in two weeks time using my modified stock exhaust manifold expecting to hit full boost by 4000RPMs. It drives reasonably well on road, has a 3582's top end without the lag.
  • Like 1
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
