Let us know how you go with the quote from RIPS, now our dollar is shite, I was quoted $13k + postage when we where at $1.20nz
Wil let you know im going the bare long motor package but im supplying a few things etc etc
who runs a gt35r .82 r on a rb 26/30 setup and how does it perform ?? is it a good combo and what power is it capable of
I would use the 1.06ar rear on a 3540. Two of my mates are running 3540's on 30/25's with 1.06 rear with power around the 450kw mark on ethanol. I would go bigger than a 3540 on a dirty 30. Fp 3794r/6466 and shoot for 550+kw :)
Depends if you want to spend the cash on the driveline.
Area under the curve wins. Bugger that big dick number in the top right hand corner :P.
  • Like 1
I agree, it's how u deliver the power rather than the peak power.
Btw, when I built my rb26/30 a few yrs back, rips racing didn't build it for me as his price was out of my budget BUT the guy is a god with 30s! I used his sump adapter plate and sump kit which wasn't the prettiest in terms of appearance, however, my engine builder at the time was very intrigued with the way it was designed which was ingenious in his opinion.
hey man robbie got back to me
for 30 4wd block and adapter and big sump,full upgrade prep,stock bottem end etc etc
6500 nzd
and he is going to do my head to im sending it to him when i get home from work i have to strip my 26 engine down thats sitting in my garage out of car.
happy days
I do, just had it fitted last week on a completely stock engined rb26. im only maiking 350rwkw to keep it safe but planning to do cams and throw in some head studs and make closer to 400. Turbo from my reasearch should get an rb26 into low 400'kw region.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
