Correction:
"On a worked engine like this, using very close to -5 turbos, I'd estimate around the 3800-4100rpm range. Once up in the revs and racing, boost will be there full time."
What fuel did they run in Group A racing?
whats your definition of "full use" how exactly do u define "full use" on the street?
-5s are the biggest you would go on a 2.6L engine, anything bigger is gonna be rubbish
if your worried about response but still want decent power, get some GT-SS's or -9s
full use as in not waiting till 4000 RPMfor boost to come on, Next thing you know your at 180kph,
-9's seem the way to go, 350kw would still be achievable with -9's and supporting mods.
thats probably why Paul recommended a stroker if u wanna go the dash -5s
but yes -9s will do 350rwkw with the correct supporting mods
If you don't want to wait then its -9s
Read the 300-330rwkw thread mate, there is simply soooo much info. No need to talk about it in this thread.
Read the existing ones, they have more than enough information for you.
GTFO with your 300kw talk.
+1 Dave. So sick of the "how do I raise my boost for free" shit threads and people wanting mega power on a shoestring budget lately!
How's your setup coming along for power cruise? Give us some good news!!!
N1GTR if you had bugger all cash would you settle for stock power? Or would you get as much as you could get?
I think what Steve (n1gtr) is saying these engines have been deveolped since 1989 and there is no magical cure for power for nothing , ive owed 5 gtr's over the years and things have gotten cheaper but getting power and moding a gtr/rb26 is not cheap you can get good power fairly easily / relitively cheap , but go over certain power and prepare to get wallet raped !my 2c
^pretty much exactly my point. Horsepower isn't free, and as Aaron mentioned there comes a point at which these cars go from a reliable fun toy which doesnt cost much to an all out black hole for money. Spending within a persons means is fine-good on people who do that, but I'm not talking about them, I'm talking about the increase in people who for example bolt on a highflow turbo, fmic, injectors etc then won't spend money on a quality ecu or quality tune and wonder why the car drives like crap.
Anyway, this is off topic, anyone in this thread with 400kw plus understands the expense and is under no illusion that certain things can't be done on the cheap :)
Exactly right, Aaron. I know more than a handful of GTR's that had $80-$100K spent on them to get over 400kw 20 years ago.
These days it is fairly easy to get 350-400kw on a low budget. Chase 500kw+ and things start to add up fairly quickly.
If you keep the power at a moderate level it should be sustainable. Then again, u hear of ppl popping engines with less than 300kw but many variables come into play such as poor tune. These work horse engines are 20+ yrs old hence a refesh should take place...whilst you are at it, u may as well set aside 20k for a solid donk with more powaaaaaa
HaHa , think im one of those 20years ago people , but like steve said anyone that has done it knows and people that have done it are just trying to help the virgins !
Getting some stuff done at Speedfab, should be back at JEM by the end of the week to get all bolted up.
Cutting it fine as usual. :rolleyes:
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
