Ah, so that was your black GTR @ Sabbaddin Automotive? :) Mine is under the blue cover, lol.
Yarp, that was mine. yours was the charcol grey one right? getting the whole rebuild and the works... should be pretty sweat when its all done, we should get together and go for a cruise when its up and running. :)
  • 2 months later...
I have read this thread a few times and like everyone else I am so confused! I want to go -7 or -9's but I am tempted to go -5's!
Why don't more people go for the -9's I dont think I have seen any dyno results of -9's, if so many people are confused like me about choosing between -7's and -5's then why don't more people go for the -9's?
Do the -9's not perform well? on paper they seem like a good compromise if you are worried about lag and want a street car.
I think that lag is also very subjective, My 34 GTR for a stockish car is great for response and I would be happy to lose a little response but the -5's some people say are alggy and others not at all.
decisions decisons!
with the -5 i was looking ordering some but they have two rear housing option a/r.64 or .86 ? what one do i pick i want around the 350-400rwkw some one help out here
my setup full built engine, cams, head work, the works really, mainly circut and some weekend driving
Edited by Travis Trayhern
decisions decisons!
Its easy Dave
Just go for a ride in a few cars :D
RPMZ, Scotsman, Ferni, myself - all running the smaller ones.
JAGR33, archie01 etc are running the larger.
Try get into those guys cars for a spin and decide for yourself, they all come from racepace with similar motors/tunes so its all in the turbos for the most part.
Street = smaller
Circuit = bigger (if you need the power)
I'd choose by seeing them in action
Thanks Ash a ride in different cars would sell me in a second I think,
But out of the smaller ones which are the better options? -7's or -9's as I think that the -9's also have the rear housing option at .64 and .86?
This is where I can not find much info, if the -9's are equiv to GTSS then which rear housing option is the way to go? is the .86 to big for the smaller turbo?
I appreciate everyones help
in regards to rear housing dont go for the larger .86 as these are suited for a single application and is overkill, as told by gcg turbos and others in the know how. will be a lag monsta!
for this reason i stuck with .64
Silva I did a bit of digging around last year and PMd a few people in the US that have genuine HKS GTSS turbos (RB26 spec ones , there is an SR 20 spec one as well which is different) .
The cartridge (center section and both wheels) has the same part number as the 707160-9 turbo and I think from memory the housings are the same as well .
Usually HKS only has unique model specific turbine and or compressor housings made if there isn't a Garrett one available to do the job .
I'm told the situation is that if HKS get Garrett to develop a unique turbo (or cartridge) combination for a specific purpose HKS has the rights to it for around 6 years . Then it's open slather and Garrett can sell it through their on distributors if they like .
If you want to go through the process ask someone who has RB26 HKS GTSS turbos to pass on the turbos ID tag numbers , then compare these with the Garrett 707160-9 turbos ID details .
I'm pretty sure they are one and the same thing but please double check , I'd hate to see you buy the wrong thing because of my fallible memory .
Cheers A .
Here are my results: R34 GTR, stock turbos vs -5s
At 0.9Bar, the -5s are behind in response till 4400RPM. The most they are behind at any point is ~600RPM. In a six speed, below 4000RPM is just for cruising in traffic anyway.
I really cant tell that it is laggier or anything, especially when it comes on boost at the higher boost setting :laugh:
I really cant tell that it is laggier or anything, especially when it comes on boost at the higher boost setting :P
I can tell :D
You basically have nothing till 4400rpm, thats fairly laggy.
Mainly because the GT-SS i have are making 15-16psi (280rwkw) a lot earlier. Im making positive pressure and a fast moving gauge from 3300rpm.
So not quite 'as stock', but very close too it.
I must agree with Ash here, those -5's on the graph look laggy, I quite like the way the stock turbos kick in nice and low and find myslef never really wanting or needing to push it over 6,000rpm...
I think Ill chuck my car on my mechanics dyno and compare it to his other customers who have the -5's that way I can have an accurate comparission between the two, as we will be using same computers and tuner.
To me those -5's look laggier than just 600rpm behind, as getting to .9 bar they are much laggier than that, they look like they feel very progressive in the lower rev range where the stockies look very punchy and responsive, the -5's don't come on boost like the stockies until 4100ish rpm
the T517z's on my car come on hard at about 4000rpm but go on to make 360rwkw... on 20psi... they are old school plain bearing turbos too... I think only go for the bigger (-5's) if you intend on pushing them... no point sacrificing the bottom end response if your not going to work them really hard up high
I have NOTHING below 4000rpm... big cams make sure of that lol... then again if I wanted low revs performance I would have stuck with the ol' GTSt... RB25 + 2835Pro S + baby cams combo, that was super progressive
I do like how you can get away with light switch delivery on a GTR though, just grips and goes! (and has passengers looking for something to hold onto)
I just reckon there is not much point having turbos that your not running decent boost through... you may as well so as small as possible and try and get the most out of them... otherwise you'll always be talking about how much you 'could' make if you wound them up... whilst not having the response of smaller turbs
Everyone makes valid points, I think the only way to decide is to hop into a car with both setup and see what I think.
Do we all agree that max boost on a stock bottom end would be approx 18-20 psi (20 at the absolute max only for -7's) I am not looking to build my engine unless it goes bang, and it is quite healthy so unless I do something stupid i think it should be fine.
- my 1st engine was running 19-20psi, after 6 mths ring land collapsed (that was a genuine 90,000km engine, aust delivered gtr with full history)
- my current was running 19-20psi, after 9 mths same thing
dont expect it to last long - dont forget these engines are pushing 20yrs now
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
