paul - u got time to overlap your graph with king87s?
Converting rpm with speed makes it confusing
Google it :P There is a brilliant one for skylines on there. CBF doing it now... Ill have a play tomorrow after work ;)
When you compare the VQ25det with Variable cams to the VQ30det without, the turbo response and power seem very similar even though the engines are 500cc apart. At a guess the Vcam (vq35 cam actuator) upgrade for the RB26 would make it feel like a 2.8 - 3L in response, although it sells with a higher duration cam I assume, which may drop response back slightly again.
King87 u made 150hp@ 100km/h = winning.. awesome top end tho! But in all honesty wouldn't 2530's be better suited to a 3.o bro or 3.2/3 for the street?
Yeah it's defantly not a bad result. It's ok to drive on the street the lag isn't that bad to be honest but guess it just depends what you get use to and like.
They would be better with a 3L pushing them for sure.
Yeah I know what to expect and I will keep you all posted if and when it does let go.
Not sure what it made on 23psi it's got 25 @ 5000 RPM I will try dig up the dyno print out.
-5's for the win for street and track but agreed they could use a few more cubes behind them
On the street.
Either dial in the cam gears or go HKS V-Cam or 2.8lt or HKS V-Cam 2.8lt.
Will help with the low down.
Makes you wonder how the Mines R34 GTR is so responsive using 2530's on a 2.6ltr engine doesn't it?
It has NOTHNG at 4500 RPM. Look at the videos. It's a lag wagon if it "falls off". People bust a nut at how quickly it "revs". 5:1 or what ever they are plus the 6 speed give the illusion it's "responsive"
Between gears it's a bulldog, but you have to keep it spinning!
so your saying it's a "bulldog between gears" (which IMO is what you want) but a pig from standing start?
Edited by Ants
Not when you launch it from redline a 26 is not laggy and when your changing gears at 7.5 k there is no lag. A 26 with -5s has to be driven a certain way to be raced properly and the motor has to be built properly for this purpose to be reliable. -9s on a stock motor is a much better setup if you don't want to kill your motor.
I believe the HKS 2530's on the Mine's R34 GTR are modified.
And the RB26 ain't stock either :)
That sounds very enticing if it would feel like a 2.8-3.0. On a 2.8 with vcam and -5 that would be the ultimate setup in terms of power and response. Antz I think you need to add a vcam to your advance spec and you probably wouldn't have to worry about going a 2.8 later down the track :)
Would love to hear from anyone who has gone from standard displacement to vcam with same turbos and comment on the results
I completely agree with you on that one. I also think there is more to response than just gearing.
Having seen the Mines R34 GTR in action (in many different videos) you simply cannot conclude it has no balls under 4.5K unless you have a dyno chart to compare it with.
Yes, they are very lightly modified with the ex. housing ported (very similar to what I did with my -5s ) but that's it. Its a built 2.6 alright but still a 2.6 and not a 2.7 nor a 2.8 stroker
Edited by Ants
Look at the video where it compares it with the supra. That left hander up the hill it falls off song and it takes a bit of time to get back to its "happy zone".
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
