Is there any truth to the fact that the HKS turbos use a steel bearing race vs the Garrets using plastic?
I'm modding up a pair of -5 garrett's at the moment, bought a lathe and measured up the stock nylon bearing cages.
Made some new cages from brass rod (there are different grades) and after a few attempts finally got 4 ready to go.
In the process of pulling the turbo's I'm going to use apart, fit the cages and fit to my car :)
Quite a fiddly and precise job!
  • Like 1
If your talking about the car I think you are, it went in another dyno and made 312kw
if this is in reference to my car's run at unigroup dyno day, there are a few factors that contributed to the low reading
1. it was boiling hot! the 370ish that was made was in winter on a cold night compared to a 38 degree day. Even Yavuz mentioned that the car's he tuned were making 10-15kw less
2. the aftermarket BOVs were stuffed and were causing a boost leak, which Yavuz could hear as well.
I ran 11.7 @ 118mph with leaking bovs too actually so there was def a drop in power
I took it back to powertune a few days later and it made 330kw with the same problem
the BOVs have now been fixed (currently has no BOVs actually)
last dyno run was around 355kw mark which as mentioned above seems to be the limit of -9s
I want to put new BOVs back on soon and see if i I can get back to that magical 370kw it once made... will need perfect conditions i would have thought
Very nice power figures for -9s. Do you have a build thread?
Is that E85??
I'm making 350kw -9s on 98 I maybe going to e85 this year and see what they can push
Probably find you won't make anymore Nick, guessing yours are falling over above 7000-7500rpm like everyone else in the boost/airflow department?
What you will get though is midrange. You can jam more boost in the mid range... That said I was running 23-24psi @ about 4000rpm on 98 that then fell back to 17-18psi (as turbos ran outta flow) over 7000rpm.
Thats what i was thinking Ash, Thats right they do start to fall over there, half the time on track im shifting at 7000-7500 as they do run out of puff in the higher rpms
A fatter midrange on track would be good and all the cooling benefits of e85 blah blah lol
Hi there has anyone had any experience with using water methanol injection setup.
I have heard some great power gains with these kits but I'm after hard evidence before I consider installing one to my GTR.
I'm running -9s on 98 Ron making 340RWKW.
Any info would be greatly appreciated.
Cheers,
Dave.
Cheers,
Dave.
http://www.skylinesaustralia.com/forums/topic/396164-lets-talk-water-meth-injection/
  • Like 1
Is that E85??
yes, mine is on e85, however my motor is stock.... only work apart from injectors is a metal headgasket, stock cams and head are probably holding back some power.
  • Like 1
having read this thread in its entirety over the last 24 hours.. i have a few comments.
firstly: people need to fking read a thread if they are going to post on it.. there must have been 30 times the question is asked "are GT-SS the same as -9's" when it was answered 8 pages earlier..
secondly: its close minded to beleive that just because all you want is instant response in a car and that someone else is dumb for not agreeing with you, or will regret not going that option down the track. people are different. peoples tastes are different. and its their right to decide what they like.. maybe it hasnt occured some that there are people who own a fast car who enjoy the rush when boost kicks in hard at 4.5-5k and they want that in their daily, because thats what they like. And they're prepared to put up with a bit of unresponsiveness. Its their prerogative to do so.
further; by saying "that setup is just going to get you to lose your license" is not exaclty a valid argument. so will doing 60 in a 50 zone, if you get caught enough times. pretty well every car on the road has the capacity to have you lose your license if you drive like a tool. Maybe the owner takes the freeway home from work and hauls ass up to 100 in second on the on ramp, and thats how he deals with the stress of life. who knows.
rant over.
im still undecided between -9s and -5s for my turbo replacement, after my tune with r32 N1s which are very lazy (max boost around 5k) they need to go! and i figure since im used to them taking their sweet ass time to come on perhaps -5s are the go for future upgradability higher top end and bearable lag. it just seems to me that there needs to be a set to bridge the -5/-9 gap..
on a side note has anyone ever used twin 2860rs's? their flow map looks like it has a more usable spread then the -5's with slightly lower peak flow.
Dan
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
