Twin 3" dumps into a 3.5 decat and 3" cat back
3in catback is too small. Disconnect the cat back and do another dyno run to see how it goes.. Also, decats are only for the sort of people who throw garbage in the street.... ie the anti-social
FWIW the Nismoid rule of thumb for exhaust sizing is;
3in for 300kw
3.5in for 350kw
4in for 400kw
plenty of 3.5" cats around....
if the sard flows the same amount as the nismo fuel pump then up to 400kw will be achievable on e85
Yeah, but the question is will a 3.5in cat match the 3in front pipe or will there be a need for an adapter?
Sard fuel pump flows exactly the same as a Nismo fuel pump.
I gained 500rpm in response time by knocking it out. Im waiting til I get my new exhaust to put a bigger one in. supposedly had a 200 cell cat in there before.
they are worse than hitler
The best logical conclusion is that my cam haven't been set up correctly when my timing belt got done after I got another dyno reading for the same HP.
5psi by 4500, 10 by 6000 and 17 by 7500....
  • 1 month later...
I have ended up with the -9's and after fitting them and running a compression test I found out that I am now needing a rebuild.. Changing the pistons, rods, cams, injectors, oil pump, cam gears etc.. would it be 'restricting' this build with -9s?
I had over 400kw and ran a 3.5inch exhaust. I never upgraded to 4inch for the reason that my tuner advised the exhaust was not a restriction.
Hope that helps :)
P.S. I'm sure there would be gains but not more than a bees d1ck (bang for buck)
  • Like 1
Anyone with a 400awkw car had a 3.5in and change to 4in and see any gains?
There's no way to tell over the internet. A rule of thumb is just that. The cat and mufflers are the most restrictive bits after the turbine, if you have a cat and muffler(s) that flow very well, you might see no difference like Marko. Ask your tuner.
If you already have a good flowing 3.5" then i would say keep that but if you need a new one then sure you may see a little gain from going to the 4" set up.
I have a 3.5" cat back making 430kw on 2530's with a stock 2.6L and is not a restriction.
Cheers
Edited by KING87
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
