haha Okay man ur pencilled in for cooler kit! ive already got that money planned for and spent before ive even got it now! haha going towards a Microtech ECU for my car! :P
neway wen u get ur money sorted from tax return ill drop cooler off to you to show you how it goes n see if we can get it in. But it may need a bit of a mod to the pipe from the turbo i think from looking closely at mine, so u may need to get somewhere to do that for u but it should be pretty cheap to organize. but we can mount the cooler itself in the front of ur car to save money if u get put in by a shop.
pod filter is like a half hour job, but u need a thin bit of metal or something to make a bracket to support it. i can show u wat mines like wen i drrop cooler off to u if u havent already installed urs by then!
n muffler u just pick the one u want from the shop n book it in, they chop ur old one off and weld on the newy in a couple of hours !
too easy! let the mods begin! :( haha cant have the old classic being left stock! haha
  • Replies 2k
Nothing wrong with white, just not ALL white.
I think mine looks cool, white/silver.
And now considering scrapping RB conversion for L31, to keep more in phase with originality. Top end HP might not be as big, but torque would be similar and  300rwhp still might be achievable.
Someone that could remark an L28 block to my L20 engine number would be interesting, no need for engineering or emissions testing then and a nice little sleeper.
have you started building the engine yet?
Hey all....
wondering how easy coilovers are easy to slap into a R30 SKyline..
whar car has similar coilovers? S-13?
any modifications required...?
ne help would be appreciated
if you read back through the posts then there is alittle info on the s-13 struts but no one has come up with an answer that dosent involve $$$ which is the crappy part.
Ok here is for the front S13 swap into a bluebird which is the same as R30's
S13 Struts into 910 bluebird
hhmmm looks very interesting, so what that says is just to use the s-13 set up? with the r30 strut tops do you think the coilovers would bolt to those or just turn the s-13 tops around to line up the bolts?? its just i dont want to have to throw my freshly painted tower brace out!!
hmm seems a bit complicated ... but i guess you could do it and do your brakes at the same time i.e. get S14 hubs and R32 brakes and some s14 coilovers. or s13 hubs with redrilled 32 brakes and coilovers. kill 2 birds with one stone.
then the rears are easy enough to bolt in if you swap the tops from your stock shocks onto the s13 coilovers i think? otherwise drill an extra hole in ur strut towers to accomodate the 2 hole s13 coilies.
my suspension is quite good and im gona get Microtech next then new bushes, but wen i do brake upgrade it may be worth getting coilovers too i guess :cheers:
yeh the whole lot; cntrl arms, hubs, suspension etc
i think there was a problem with swapping the strut tops, not 100% sure, but i know u need to use coilovers because the std spring is too wide and hits the tower on full lock.
they are all drilling their strut towers out for the different stud pattern, cos its IS stupidly different (Hey isn't that like a big no no from nissan/datsun??? everything is supposed to be bolt on swap!!!)
got my car back today with the big Hybrid in the front, looks pretty mean with that cooler in there :mad:
Sard BOV is a loud bugger too but nice clean sound just PTSH no fluttering. goes well. am resetting the ECU tonite to let it learn with new cooler but just as it was today it went well !
cant realy be bothered resetting ECU unplugging battery terminals but i guess its best to do it :)
oh i added pics of the cooler install to my Gallery. even tho it probably still says i have zero pics they are in there!
I have a pair of Brand New GReady S13 Strut Tops, bought from JMS in Adelaide for my original R30 project and the bolt pattern is identical to R30, BUT IN REVERSE, the problem then is that the camber adjustment is no longer to negative, but to positive, not something that would be desireable, I wouldn't think.
Noltec in Thornleigh NSW will make adjustable strut tops on request for ANY vehicle, using a urethane bush at the top, instead of steel.
[ant] - Cooler looks awesome. Did they use 3" intake side + 2.5" turbo side??? I also like the coke bottle radiator overflow bottle. What holes did they have to cut in the front of the car to allow cooler pipes to run through??
']got my car back today with the big Hybrid in the front, looks pretty mean with that cooler in there :)
cant realy be bothered resetting ECU unplugging battery terminals but i guess its best to do it :(
how'd you go with the lower lip and the fitment of the cooler? i had to shave about 1/2" of it to let my hybrid sit in there but i think mine sits lower than yours. also wish my plenum was on that side as it would save about 1.3ms of pipe! i think theres some pics of mine about 20 pages back.....made a huge difference in the power...NICE one mate..
In regards to brake discs, I can't get the DBA's that Ghostrider posted the numbers for here :cheers: Our supplier won't order them until they get a certain number of people interested. All that I'm able to get are some RDA discs (apparently the same as Brembo, but I dont know if the guy was spinning me some crap) which have to be ordered from melbourne and are $160 each
Can anyone help me out? I'd like to know what the DBA's retail for interstate and if any retailers there would be able to mail/freight them to me, or if $320 is an ok price? (FRONTS ONLY)
Ta
Ta
went i got my DBA slotted fronts i just ordered then through autobarn! i did pay $340 each for them as they make them when ordered no stock kept at all??
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
