Just got back from EC where nissan aus where test driving 3 GTR R35 ( white silver and black ), they have the driver that set the lap time at NUR putting the cars through their paces.
not sure if allowed to do this but they didn't stop me from taking photos so here some are ( sorry about there size don't know how to resize)
https://www.sau.com.au/forums/topic/258072-r35-eastern-creek/
wow, any word on the lap times?
While i was there they where only playing with cones, corners and stuff no full laps where done at pace,
was not happy i had stopwatch ready and to see how they compared too my high 1.45s and see how far off my 32 is to a new GTR.
the one at power cruise immobilized itself !
It was stuck in park and the steering was locked. Appartently someone played with the steering wheel which put it in security mode?!?!?!
If its anything like the JDM ones, there's some security feature where the car shuts down if a certain button is pressed without the key in that ignition (or that proximity dongle thing in range, I forget).
I had a chat with Carl at a Circuit Club event, and when he let people sit in his R35 he told them specifically not to press something or he'd be stuck there for hours. You can re-mobilise the car, but its a massive rigmarole with a really long instruction sheet.
my kids are going to have a ball with that feature
Well I read in the newspaper that they did have the very same driver that set the nurburg lap times, there at eastern creek...but no mention was made of lap times etc.
Sounds like it was more of a media hype day than performance benchmark...
There were no laptimes because Nissan's policy is to modify the circuit with cones. They do this for a few reasons, to prevent unskilled journos killing themselves full tilt down the main straight and to prevent onlookers taking unskilled journos laptimes as a benchmark for how the car can perform.
They had a mandatory cone chicane and a slalom on the main straight.
Fair enough too - but I thought I read that the nissan test driver who set the lap times at the nurburgring was there at EC? Surely he could've spent a day out there and given us a lap time? although a day might not be enough, going by how long it generally takes the v8 guys to really nail a circuit.
Suzuki-san was there but it isn't his decision. He's an employee just like everyone else and this policy is handed down by management types ;) .
When they told everyone why the cones were there they handed over to a representative of Nissan Japan who gave the explanation and was very sorry but it's the global policy etc etc.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
