^^ if a tank is completely sealed how can 98 go off?
tanks aren't sealed, they have a breather on them which goes to your charcoal canister. 98 goes off because the volatile chemicals evaporate, ethanol is 85% high octane stuff so if you lose some ethanol to evaporation all that happens is you have a bit less fuel than when you started. petrol is low octane base with some high octane additions and if these evaporate then you are left with shit fuel.
the main danger with ethanol is when it absorbs moisture, it will form two different layers in the tank with the water concentrated in one of the layers and this is obviously bad for your motor. it's a much bigger problem in boats because it's easier to get water contamination, in a car it's not so bad but something to be aware of if you let the car sit for long periods of time (especially outside - in a garage it would be fine).
When you say breather, it is a vac line so the tank has constant neg pressure. I can only go by my own previous experience and say if you leave 98 in a sealed container it will turn to crap over a few months, I will know with ethanol after next weeks experiment...
I don't see moisture as an issue in the amounts we are talking about, better that it mixes than sit in the bottom of the tank.
  • Replies 489
It seems to be a popular misconception due to the problems with methanol storage and acidity.
you mean due to rumors circulated by oil companies... ;)
yeeeeees... into my "charcoal canister" which i totally never removed... >_<
Ive had my car sit in the garage for just over 3 months with a full tank of E85. Had no dramas when i drove it again.
i've used some e85 that i had sitting in a 20l sunoco tin in the garage on a milkcrate for over 6 months and it was fine :D
quite a good, comprehensive article
http://theage.drive.com.au/motor-news/is-s...0806-11mog.html
Manildra alone is already sitting on a lake of 100 million litres of fuel-grade ethanol, just waiting for buyers.
>_<:D;)
wonder if these are cheaply available and easy to install/hook-up
There's even a piece of equipment mounted in the fuel tank — very similar to a police breathalyser unit — that can detect how much ethanol is in the fuel and retune the engine's electronics to suit the mix
Yep the sensors most certainly are. The only problem is you basically need a motec to take advantage of them, basically you need two maps, one with petrol one with e85 and then you need to interpolate between the two using the sensor. Ultimately you would create 4 or so maps in case its not a linear relationship between the two fuels and have the ecu interpolate between them all. Not really that cheap to set up, but very effective when done, almost all new cars from the factory are capable of doing this.
Edited by Rolls
the pricks didn't post my second comment
"To Barry Park: Can I convert my existing Commodore to run on E85?
No"
This is incorrect. Most commodores getting around these days can be converted, and if you got this info to the contrary from Holden, they're basically lying.
They posted my first comment in a matter of minutes, but the above has gone MIA - Barry Park is the author.
EDIT: tried again, still won't post it the pricks.
motec = $ = problem :)
the link/vipec computers can use the Siemens E85 ethanol content sensor, trent might be interested to have a play around with one and see how it works?
Yeah any computer that allows a 3rd dimension to the fuel/ignition maps will be capable of doing it. As currently most fuel/ignition maps are controlled via rpm and airflow. They have trim maps based on TPS etc sometimes but to use an alcohol fuel ratio sensor you need to modify fuel and ignition, and its not linear, need a complete map.
This could be an awesome excuse for me to get a vipec
cycly idle wank FTW!!!
I'm doing another formal drop off at the end of this year and im thinking the cycle idle on the Vipec going into my car will come in handy :P
But yeah the Vipec being able to adjust the map with the sensor in the tank for the E85 sounds like a great plan!
Edited by PM-R33
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
