i guess i do. im just going by that chart, that says the G2 is rated for 450hp (not sure if its @crank or @wheels)
The chart say 450hp - that is not 450rwhp.
450hp is @ the motor... ALL turbos are rated in such a manner
You can check for a OP6 rear. We will have the the bigger rears soon. The engineering place just take their time doing it. Hopefully be available in Mid May.
Hello Stao!
I have a vg30det turbo 4V54 front with OP6 rear sitting in the shed. I would like to no how much for a high flow? it is for for my RB25DET Cefiro street car so i'm trying to keep resonse in mind while still achieving as much power as possible. Having said that, wats gonna be better ball or bush bearing?
The high flow will cost $800 plus $80 oil feeding line. We will be using ATR28G3's profile which should get you around 260~270rwkws (OP6 rear) with supporting mods at peak and not too bad down low either.
Edited by hypergear
With R33 stock housing its very close to its limit, maybe another 5~10 kws once leak fixed.
With RB20 turbo's high flow I'm not too sure as I haven't had one dynoed yet. I guess its probably archive close to 230rwkws.
Wheel size wise this is using the a 71mm comp with 65mm turbine. With Garrett GT2871Rs its running the same size comp wheel but 53mm turbine.
I'm guessing you mean 71mm comp with 56.5mm turbine. I guess you use this on the larger rear housings as the stock R33 rear housing isn't large enough?
Would the larger rear housing turbo be suitable for a remapped ECU R33 car if only running 9psi? (currently runs fine on 10psi stock turbo)
As a replacement for stock turbo until I get off my arse and get injectors, AFM and powerFC?
We do use 65mm Turbine. Need some thing to flow as possible in a small turbine housing. If you can get a OP6 turbine housing we can use ATR28G3 CHRA with 76mm comp wheel. That will be able to get you over 250rwkws. You can drive it on low boost no problem, as for the best results get it dyno tunned with Power FC and supporting mods.
As for RB20 using ATR28G2 hi flow you can probably get some where between 200 to 230rwkws.
Edited by hypergear
Any way adding some photos of the OP6 reared hi flows.
This is a complete ATR28G3 high flowed into a OP6 Rear housing (note the mark on the housing)
GT2871RS CHRA high flowed into R34 OP6 Rear with stock comp housing:
This is a Custom made GT3076RS in a .63 Rear internally gated setup bolton to stock Manifold
Edited by hypergear
Will the larger rear be 0.7 A/R with skyline bolt pattern? I want 230rwkw at about 1 bar or less, I'm thinking a 2871 would get there easier with the slightly larger housing.
Is R33 rear housing 0.58 A/R?
And where did these 0.7 A/R housings come from? Couldn't they have made them 0.82 or something to flow a bit more?
Edited by simpletool
The larger rear would be a .63 rear with RB25's bolton pattern. If you perfer 230rwkws BB GT2871 CHRA should do it fine. You can get that with stock turbo's rear housing. Stock R33's rear is only .48
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
