TR43 G2 is running a .63 rear which is what the OP6 Rears are. But with a Vband rear. If you have a OP6 rear already then we can just high flow that. Less headaces when putting every thing back. Response wise I would say its touch bit laggier then before high flow.
TR43 G2 is running a .58 rear which is what the OP6 Rears are. But with a Vband rear. If you have a OP6 rear already then we can just high flow that. Less headaces when putting every thing back. Response wise I would say its touch bit laggier then before high flow.
TR43 G1 trims seem to be making around 240rwkw on 20ish psi on RB20's
so i'm assuming that since a G2 is meant to be 30hp larger your should see around 255-260rwkw on similar boost?
how would this compare with the gt2076r 0.63 internal gate custom tubro you posted a few pages ago?!?
ok now, so now that is stated.
my theory is IF you are chasing 250 RWKW in a R34 with a OP6 housing the best choice is to HIGHFLOW it.
IF you do NOT have a OP6 your better off going a TR43G2.
when i googled Hypergear i cam across a supra forum and i believe you were making a TR43G3. If so will that bring around 270Rwkw?
regards
Chris
TR43G3 is later on called a TR43i. Yes we've maxed that on a CA at 300rwkws with 24psi of boost. For standard build RB25det engine with 19psi of boost internal gate. it should get some where around 250~270rwkws.
We also managed to high flow GT15 turbo off a single soarer with ATR28G3 spec. The GT15's got lot bigger turbine housings. So in case you got a Soarer with a blown turbo we can also make it work.
interesting as we do a lot of jzx100's here. Got 2 in car park now :dry:
so what turbo would you suggest to run on a stock rb20 trying to make 260rwkw on 20-24psi of boost?!?
has to be low mount to bolt onto the stock manifold and internal gate with the best response possible...
im thinking the TR43G2 but maybe its not big enough and should go a TR43G3 (aka TR43i???)
Edited by Cerbera
Guy on here used to have one he said 18psi at 3800 (that what he set his PSI too) so for something that could make 300kw thats pritty good, and that was with no cams just injectors afm and ecu and a light tune was 245kw.
So with cams better ecu and right tune sould see some good power.
Oh and it was a GTS-4 so RWD should read higher power.
Edited by raZ1911
Hoo yea. thats that Black R32 guy. Its abit of sad funny as I rang him for a copy of dyno sheet and he was asking me if any one found his car any where.
So is 250-270rwkw your highest rated hi flow for an rb25, i currently have a hi flow with a vg30 rear and core with an rb25 hi flowed front and bigger wheel (specs are HERE ) and i have a blown standard turbo, what are the chances of making something that will get around 300rwkw with an auto?
Assume you have a strong enough Auto box, you need some thing at least in .63 rear housing to do that. We can make a .63 Vband reared ATR28G4 which will get you about 300rwkws at 20~24PSI depends on mods. The OP6 Rears won't do it. But the VL's RB30 .63 rear housing can do it.
What what the price be on one of those and will the oil and water lines be a direct bolt on or will they have to be custom as well?
The price is $1060 including 14psi internal wastegate and Braided oil feeding line. Your Stock water lines fits. The rear end of the turbo is a 2.75 inch Vband, We supply the O ring for dump pipe making, and most of your local exhaust shops can make the dump made for roughly $200.
Would the hks adjustable wastegate i already have fit?
If its made to suit a T3 turbo It should. It depends on how long your actuator's extender is.
I have it on the hi flow thats on my car atm, dont know how long the rod is ive never screwed it all the way out.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
