Douse Posted May 20, 2009 Share Posted May 20, 2009 Are there any dyno printouts of this? I would like to know how laggy the TR43 G2 would be on the 2litre... Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4606130 Share on other sites More sharing options...
Douse Posted May 20, 2009 Share Posted May 20, 2009 I am actually running a RB25 neo turbo at the moment....would the lag be the same or would it be a little laggier? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4606171 Share on other sites More sharing options...
hypergear Posted May 20, 2009 Author Share Posted May 20, 2009 TR43 G2 is running a .63 rear which is what the OP6 Rears are. But with a Vband rear. If you have a OP6 rear already then we can just high flow that. Less headaces when putting every thing back. Response wise I would say its touch bit laggier then before high flow. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4606455 Share on other sites More sharing options...
SimonR32 Posted May 20, 2009 Share Posted May 20, 2009 TR43 G2 is running a .58 rear which is what the OP6 Rears are. But with a Vband rear. If you have a OP6 rear already then we can just high flow that. Less headaces when putting every thing back. Response wise I would say its touch bit laggier then before high flow. TR43 G1 trims seem to be making around 240rwkw on 20ish psi on RB20's so i'm assuming that since a G2 is meant to be 30hp larger your should see around 255-260rwkw on similar boost? how would this compare with the gt2076r 0.63 internal gate custom tubro you posted a few pages ago?!? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4606603 Share on other sites More sharing options...
urtwhistle Posted May 20, 2009 Share Posted May 20, 2009 TR43 G2 is running a .58 rear which is what the OP6 Rears are. But with a Vband rear. If you have a OP6 rear already then we can just high flow that. Less headaces when putting every thing back. Response wise I would say its touch bit laggier then before high flow. TR43 G1 trims seem to be making around 240rwkw on 20ish psi on RB20'sso i'm assuming that since a G2 is meant to be 30hp larger your should see around 255-260rwkw on similar boost? how would this compare with the gt2076r 0.63 internal gate custom tubro you posted a few pages ago?!? ok now, so now that is stated. my theory is IF you are chasing 250 RWKW in a R34 with a OP6 housing the best choice is to HIGHFLOW it. IF you do NOT have a OP6 your better off going a TR43G2. when i googled Hypergear i cam across a supra forum and i believe you were making a TR43G3. If so will that bring around 270Rwkw? regards Chris Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4606701 Share on other sites More sharing options...
hypergear Posted May 20, 2009 Author Share Posted May 20, 2009 TR43G3 is later on called a TR43i. Yes we've maxed that on a CA at 300rwkws with 24psi of boost. For standard build RB25det engine with 19psi of boost internal gate. it should get some where around 250~270rwkws. We also managed to high flow GT15 turbo off a single soarer with ATR28G3 spec. The GT15's got lot bigger turbine housings. So in case you got a Soarer with a blown turbo we can also make it work. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4606775 Share on other sites More sharing options...
geraus Posted May 21, 2009 Share Posted May 21, 2009 looks very nice Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4607894 Share on other sites More sharing options...
STATUS Posted May 21, 2009 Share Posted May 21, 2009 TR43G3 is later on called a TR43i. Yes we've maxed that on a CA at 300rwkws with 24psi of boost. For standard build RB25det engine with 19psi of boost internal gate. it should get some where around 250~270rwkws.We also managed to high flow GT15 turbo off a single soarer with ATR28G3 spec. The GT15's got lot bigger turbine housings. So in case you got a Soarer with a blown turbo we can also make it work. interesting as we do a lot of jzx100's here. Got 2 in car park now Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4607910 Share on other sites More sharing options...
SimonR32 Posted May 21, 2009 Share Posted May 21, 2009 (edited) TR43G3 is later on called a TR43i. Yes we've maxed that on a CA at 300rwkws with 24psi of boost. For standard build RB25det engine with 19psi of boost internal gate. it should get some where around 250~270rwkws. so what turbo would you suggest to run on a stock rb20 trying to make 260rwkw on 20-24psi of boost?!? has to be low mount to bolt onto the stock manifold and internal gate with the best response possible... im thinking the TR43G2 but maybe its not big enough and should go a TR43G3 (aka TR43i???) Edited May 21, 2009 by Cerbera Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4608184 Share on other sites More sharing options...
hypergear Posted May 21, 2009 Author Share Posted May 21, 2009 ^^^ TR43i external gate. at 24PSI it will get you over 260rwkws. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4608991 Share on other sites More sharing options...
SimonR32 Posted May 22, 2009 Share Posted May 22, 2009 can it be used as internal gate?!? external gate is not a option... Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4610165 Share on other sites More sharing options...
raZ1911 Posted May 22, 2009 Share Posted May 22, 2009 (edited) Guy on here used to have one he said 18psi at 3800 (that what he set his PSI too) so for something that could make 300kw thats pritty good, and that was with no cams just injectors afm and ecu and a light tune was 245kw. So with cams better ecu and right tune sould see some good power. Oh and it was a GTS-4 so RWD should read higher power. Edited May 22, 2009 by raZ1911 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4611024 Share on other sites More sharing options...
hypergear Posted May 22, 2009 Author Share Posted May 22, 2009 Hoo yea. thats that Black R32 guy. Its abit of sad funny as I rang him for a copy of dyno sheet and he was asking me if any one found his car any where. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4611232 Share on other sites More sharing options...
W0rp3D Posted May 23, 2009 Share Posted May 23, 2009 So is 250-270rwkw your highest rated hi flow for an rb25, i currently have a hi flow with a vg30 rear and core with an rb25 hi flowed front and bigger wheel (specs are HERE ) and i have a blown standard turbo, what are the chances of making something that will get around 300rwkw with an auto? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4612034 Share on other sites More sharing options...
hypergear Posted May 23, 2009 Author Share Posted May 23, 2009 Assume you have a strong enough Auto box, you need some thing at least in .63 rear housing to do that. We can make a .63 Vband reared ATR28G4 which will get you about 300rwkws at 20~24PSI depends on mods. The OP6 Rears won't do it. But the VL's RB30 .63 rear housing can do it. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4612188 Share on other sites More sharing options...
W0rp3D Posted May 23, 2009 Share Posted May 23, 2009 Assume you have a strong enough Auto box, you need some thing at least in .63 rear housing to do that. We can make a .63 Vband reared ATR28G4 which will get you about 300rwkws at 20~24PSI depends on mods. The OP6 Rears won't do it. But the VL's RB30 .63 rear housing can do it. What what the price be on one of those and will the oil and water lines be a direct bolt on or will they have to be custom as well? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4612396 Share on other sites More sharing options...
hypergear Posted May 23, 2009 Author Share Posted May 23, 2009 The price is $1060 including 14psi internal wastegate and Braided oil feeding line. Your Stock water lines fits. The rear end of the turbo is a 2.75 inch Vband, We supply the O ring for dump pipe making, and most of your local exhaust shops can make the dump made for roughly $200. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4612494 Share on other sites More sharing options...
W0rp3D Posted May 23, 2009 Share Posted May 23, 2009 The price is $1060 including 14psi internal wastegate and Braided oil feeding line. Your Stock water lines fits. The rear end of the turbo is a 2.75 inch Vband, We supply the O ring for dump pipe making, and most of your local exhaust shops can make the dump made for roughly $200. Would the hks adjustable wastegate i already have fit? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4612501 Share on other sites More sharing options...
hypergear Posted May 23, 2009 Author Share Posted May 23, 2009 If its made to suit a T3 turbo It should. It depends on how long your actuator's extender is. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4612638 Share on other sites More sharing options...
W0rp3D Posted May 23, 2009 Share Posted May 23, 2009 If its made to suit a T3 turbo It should. It depends on how long your actuator's extender is. I have it on the hi flow thats on my car atm, dont know how long the rod is ive never screwed it all the way out. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/5/#findComment-4612889 Share on other sites More sharing options...
