Hi Gargus. Yes I ended up making a gig and mount every single housing to it before machinery work. It turned out in identical shape and spacing to the stock turbine housing. I fitted one to my own R33, went in all easy no problems at all. I also tried to boost it up and down with a EBC. Went up to 20psi no worries and also holds on 7psi no worries. I'm currently running on 7psi with all stock gears. pulled harder then stock turbo running 14psi.
Depends on what it is and parts availability. Roughly 3 to 5 working days to have the turbo built before dispatch.
Awesome. Are you able to tell me, if mine has been dispatched yet?
so what is the best choice for 400rwhp.. external gate.. and i dont want to run anymore then 20psi on pump fuel, i want a turbo that will give me 120mph at the strip....
That would be a ATR45 in .82 turbine with .70 Comp. Its rated to 600HP we can build that in sleeve bearing for $1400 or Ball bearing using GT3582R CHRA for $1800.
Hi Stao, did you end up tuning that R33 at Status today? if so how did you go with the waste gate actuators? im thinking maybe going for a 14psi 1 straight up and seeing what that does to mine. tell me what u think.
regards
Chris
my injectors didn't arrive till late this afternoon so my tune was rescheduled till Wednesday. I had a play with my EBC using the 14psi actuator. I can rise it any where form 13psi and above, not below. I will post some sheets once I get it all tuned and running on Wednesday night.
standard high flow is $880 with oil line. That should get you around 235rwkws max.
We can also do a 250rwkws high flow based on your stock housings which will cost you $1000 with oil line and 14psi actuator.
This is Part 1 footage of our 344rwkws ATR28G4 (ATR43G3) S13 drift car at winton last month. Enjoy:
I will upload part 2 and part 3 tomorrow.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
