kwickr33:
Yes we have internal wastegate kit for your turbo. will cost $200 with bracket and high pressure actautor.
Gtscott:
We buy Garrett bearings, seals plus certain bearing housings and we do our own assembly.
Hey Stao, I'm looking to upgrade to a TR43 G1 with a .63AR in the next month or so.
What sort of wastegate actuator options do I have?
I know you don't typically make them with anything less than like 10psi for skylines etc.
but for my X-trail, i need a low boost setup to work off before i raise the boost with a controller.
If I was to order one, can you include a 5psi actuator?
Thanks!
Little update:
I've managed to build a "HKS2530" in a larger .86 T2x turbine housing with OEM RB25det bolton pattern for RB25det engines. Should produce identical amount of power with similar response and better torque for the Rb25s.
Photos:
any chance you have a garret gt30 ex hausing with rb style flange on there do you?internally gated if possible
Yes we can do that.
The GTRS would be a smaller trimed 2871R. I'm also building one with larger comp trim. My engine is almost finished. I will put that on and see what happens.
im just looking to buy a garrett gt30 rear exhaust housing,i believe the genuine garrett option is best suited to my turbo,gt30 71r non cropped turbine
The genuine Garrett GT30 internally gated turbine housing I have a listing for $650AUD including GST brand new in .82 A/R.
Can i ask, which turbo and housing is best for r33.
Thing is: i dont wanna upgrade injectors, PFC, z32 etc.
I just want to run MINES ECU, Bosch fuel pump, exhaust and cooler on 14 psi, (stock injectors and z32). So around 225kw is probably aim, but would have to be responsive.
Stao how are you mate...
im after a turbo for my car gt 3540 - 2530 but i want the power of the 3540 with more response... is there a half way kinda turbo out there td06? or something i was told.... now im after 230 awkw on the gts4 but im gona want more later on..... ive spoken to you late last year.. about this but theres so many to choose from.. whats gona be best for my rb20 ?
regards George
That is the easiest question ever to answer.... the factory turbo, as your Mines ecu is tuned only for the std turbo and std afm. It will run with the z32 but the map scaling will be up the shit.
If you do swap the turbo it will just be a matter of time before you have a nice mess on your hands.
regards George
A gt3540 will make 400rwkw a 2530 will make 230rwkw..... big difference.
Hi George you can use our ATR43G3 in .63 turbine. It can get you about 240~60rwkws internally gated on RB20det with full boost around 4500RPM or some thing like this:
This is a ATR43G3 .63 turbo with built in External gate that is designed to bolton to stock RB20det's manifold, dump, and all lines.
Above was built for a Rb20det customer.
Also like to add all of our HPVA external wastegate are equipped with a Genuine Tail 38mm external gate Diaphragm:
Stao will the ATR43G3 in .63 turbine do 230-260 awkw comfortably ? i dont wana be driving around on 21 pound lol
also if i can get 260 kw i think thats plenty coming from an rb20... might stick to the atr43g3 with .63 also price it with internal gate please ta!
Edited by v8tzr
Yes you need to run 20psi to get about 260rwkws with stock rb20det. This engines need abit of boost to make power.
For comfortably I would say around 245rwkws. with about 18psi of boost.
Price? on one of these? will be purchasing within the month..
Price on those is $1450 including braided oil feeding line and GST. will cost $150 more If you want external gate built it, which is highly recommended for high boost applications.
This also includes 12 month warranty for all high performance applications. Means your warranty does not void if you run 24psi every day like I do and drift it 24/7.
hey stao,
Im running the older version of your turbo turbo the tr43i .63 on a r33 on 17.5 psi and getting fullboost at about 4500 and 260kw, wondering how much difference your new atr43 g3 would run? would it be less laggier?
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
