Ive now got the ART43SS(the original one) fitted onto my car. Currently untuned but this thing sounds so nice, and deep not like the standard turbo. You can definitely feel the low down difference but thats not to say its bad. By about 2900rpmish I was already making about 10psi on the 17psi actuator and held that for about a few more thou rpm. Felt nice, sounds VERY different. Even the exhaust note is different. The flutter when backing off throttle is awesome. Cant wait for this f**king rain to piss off so I can get it tuned! Will report back with my dyno and my review! EXCITEMENT!
Thanks for the feed back on the SS-2. Please run a BOV (just in case you are not) and reduce the “surge dose” to minimum as it could damage the comp wheel and shaft on high boost.
While tuning please make sure it has at least 3inch hard intake pipe with pod, unrestrictive cooler and exhaust.
I've posted the timing and fuel map of it on my car in page 75. Please print those and take them to your tuner as reference. Should be able to replicate my result with those data.
We have a 3" hard pipe all the way to the connector to the AFM and then an Apexi power intake filter. Running a genuine hybrid intercooler with a HKS exhaust. Just need to sort out my cat as it is currently standard.
Did you use the standard r33 blow off valve and did it hold boost well? I just need a pipe to connect my BOV back to my return.
Also my boost controller(profec B spec 2) is playing up now. The lo icon in the top of the screen is flashing and this only started since I installed the turbo. I don't know whats going on there....
with the exhaust if its got a stock cat you would likely to have a 2.5 flange on the ends of the pipes, Please make sure all exhaust plumbing are in 3 inches.
Mine held boost pretty well, I didn't had issues. I don't know much about th EBCs, I think manual boost controller worked best.
As for the BOV please check this page:
http://www.skylinesaustralia.com/forums/index.php?showtopic=261613&view=findpost&p=5190870
thats how its setup on mine
I will probably get a new EBC if this one is not working. I will try the standard setup and Ive got another BOV to fit on if I need to.
Ive got a 3" bellmouth dump pipe with 3" flanges and 3" to 3.5" HKS exhaust. I will get the tuner to gut my cat or fit a high flow cat during tuning.
Its all talk till I see the graphs. :P
I havent heard of anything other than shipping the ecu over to Japan for a guess-flash. I was hoping there would be a better option by now, considering im about to push for 350+
HPF 100% do it i saw some 350z graphs, saw some gains so i presume its legit.
I have a turbo vq35 coming in 2 months so i need a solution before then :P
I really wish he did. unfortunately he did not get back to me ever since. He also stuffed my 300ZX during a turbo change last year for the ATR25 development that coasted me $6G to get it back to working order, he tried to make up for it back then. How ever he did do few good less complex jobs as most people I referred him on turbo changes are satisfied with his work.
I believe there are two types of business/trades people:
1. People whom are using his/her skills doing their best to benefit the broad society.
2. People whom are using his/her skills doing what they could to benefit him/her self.
As the manager I feel I must have the knowledge and responsibility to ensure our customers receive the full benefit of our produces, be responsible and supportive to customer's needs regardless if the deal resulted in profit or lose. Same rule applies to my engineering team, and my tuners. Every job must be done properly to suit its purposes.
people whom are irresponsibility for their work / products cares only for their own benefits are not the type of people that we want to deal or work with.
Graph is on the dynosheet section:
http://www.skylinesa...ost__p__5847954
I believe Toshi have done great jobs and well proven by his results. Personally I would still prefer to get my tune done on a dyno by an experienced tuner. I have meet a ford engineer, been told that all XR6 / 8 ECUs are individually adjusted to suit specific engines as data sent from individual sensors varies.
hey Stao we are talking vq motors not rb25 :P
At moment not. Only done 2 sets this year with stock actuators and the owners all seemed to be the install and drive it type. I've been told they feels nice but not sure how much power they are making with all the stock gears. No one has made any complaints. In theory both of those should be maxing towards 500HP as a simultaneous twin.
I'm building ATR43SS-1 for the DIY project will have it finished with some photos soon.
Cool
Are you able to do anything with the stock CHRA's? or is there no choice but to use the GT28s?
Where would I get one of these oil-lines you are using for the feed?
FEED
Those are braided hose half meter long with straight hose tail on one end and a 90 degrees hose tail on the other. You can generally buy from any hyduralic hose places. The engine fitting is M12x1.25 and the turbo fitting depending on the thread that the builder has drill.
Cool
We use ATR28G1 CHRAs which is equivalent to a 2860RS-5. Need different bearings, different sized shafts and etc, probably cost more to fit them all into factory bearing housing. New lines are required fitting them back into the car.
Fair enough, was trying to get away with the factory lines because they are a huge pain to get to even as factory, cant imagine what it would be like trying to tighten water feeds on the sides that face the block.
Thank you, much appreciated - really!
I noticed from your 'fit yourself guide' that the water lines do not fit straight on.
Is loosening the brackets enough to make them fit, or would one need new water lines for this?
You find the water lines are about 5mms behind. The chassis side is pretty easy to reach, For the long one comming behind the engine, There are 2x brackets holding it on to the head, you see it if you trace it back, once they've been released that line would move pretty freely. and that will fit.
Add: Took few photos of the high flowed M35 Stega turbos. They are off a smaller combination then the usual 21U and OP6 units for better on road response working with factory Auto.
This mainly applies to the SS-1 units as they bearing housing setup is very different. High flowed units using generic T3 bearing housings are lot easier to fit factory water lines with.
But either there are no issues using factory water lines.
Continuing with the SS-1 Installation. I've got all the parts for the SS-1 machined and made today. Took 7 hours labor to have all the bits machined, welded and touched to spec. For some people the outer appearance might be considered "rough", from engineering point of view I think its a work of art. All pressures are carried out suiting their building purpose.
SS-1's CHRA is in:
I'm sitting it up on a dummy manifold first to ensure the comp housing clears:
Comp housing is now fitted with actuator angle adjusted
Fitting on the stock dump pipe:
The L pipe that goes from the out let of the turbo to factory cooler piping is a 90 degrees 2 to 2.5 inch reducer, I would prefer if you can get the long leg reducers. Mine is a short leg which needes a small piece of 2.5inch metal extender.
I would like to run a 4inch metal intake pipe, To fit that on to the 3inch inlet you can either run a 45 degrees 3 to 4 inch reducer or install a hard rubber sleeve. My intake pipe is made out from a 45 degrees 4inches hose, with a 40cm long 4inches metal pipe and a $10 pod filter from Auto baron.
PMs replied. Cheers.
Since the illustration car is going to be a daily driver I would prefer every thing to have the factory appearance. I remember mentioning the SS-1 high flows couple of pages back and here it is:
This is the machined and modified comp housing, as mentioned earlier the stock surge slot has been taken care of: (can you notice how that was removed?)
Before I have all the bits for tuning, I would like to stick with stock actuator. I've modified it and made it adjustable (to certain extent only).
Turbo is on the manifold:
Actuator is adjusted and fitted:
And Factory turbo outlet is installed.
I've arranged a mobile mechanic to install it tomorrow afternoon. Will post more photos as he work through.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
