Little update:
This is from the very first ATR43SS1PU (or referred as a small trimed ATR43ss2) which was fitted to a R33 with rebuilt auto:
In general Auto would lose around 20~25kws depending on how it was treated. So manual result would be around the 280rwkws mark.
Any way, SS3 with .83 dual gate rear is built. Will be tuned this weekend, hopefully getting the 350rwkws+. The GenEses charger is almost ready, will post some photos later in the week.
When you say the auto is rebuilt do you mean a standard rebuild or it has been modified, been thinking about going auto just unsure how much rwkw they hold standard and how much needs to be done to them to hold around 300rwkw as a manual
Think MV's rate them to 320rwkw with just a shiftkit and big trans cooler
cheers
darren
cheers
darren
Thanks for the info, been thinking about making mine auto for a while, if thats all it needs then i may just do it!
yes Auto spools faster and no boost lose during gear shift. They can sit there and do burn out all day.
yeah i drove a boosted auto r32 onetime and totally loved it..just floor it and hold on to the steering wheel while you drive down the road sideways :D
much better and faster for street and drag racing than manual...
I have one for sale too :)
I wont be doing it for a few months but pm me details and i'll drop you a line when im ready to do it and see if you still have it.
Need ATR43G3 or G4 to work on the RB2530det. Not sure about SS3 in .83 but all other SS series are too small for that engine.
Heres my 30/25det with ATR4G3. Only revs to five grand as injectors ran out of flow and we were unable to get it to hold low boost to rev the thing out.
I will reupload once its tuned with new injectors to find out what it can really do.
I shit my pants on 19psi.
You do get used to it though, very quickly :( Already considering upgrading again. But the amount of money I would need to spend just to get 40-50 more hp, can't justify it at the moment. Maybe when I can afford to forge then I'll go all out.
You can get up to about 300rwkws safely on 98 fuel with stock engine. Ask Stao to upgrade it to a G3 with .82 rear housing, He's done it to a mate for $200. Very big difference in power delivery.
Edited by GeorgesR34
Which turbo do you have? I've got the ss2 and the feeling everytime gets me pumped. Do you run e85? Forging the motor won't give more power, only forge if it pops otherwise I'll be buying an rb30 block :)
Yes, I'm currently making about 260rwkw. Thing is with sending off my turbo for Stao to modify, I live in Perth... So that's a huge down time for my daily confused.gif
I've got the G2, .64 housing. It's still just as quick, it still scares the pants off any mates that get in my car. It's just that I'm used to it now, 350rwhp got old quicker than I expected :(
No E85 in Perth, not at the pump anyway. I know forging won't give more power haha, I meant that when I can afford it I might forge and go for 500+.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
