Just remember to do it on a freeway lol, don't want anyone being arrested.
I was just gonna squirt it down the same road lol but Its better on the freeway because the road is smoother. 6krpm in 3rd gear is close to 140km/h. The car feels pretty dead coming from 1500rpm in 2nd, should be interesting to see how it goes from 3rd at 2k.
Yeah from 4900.
Dude.. It should be ON just after idle and OFF somewhere around 5... Turning it on at 5 would make your spool SUCK and your power rubbish. Please clarify the above?
& LOL @ the sarge in his army prints.
I just has a look in FC Edit and it only has VCT: then a value. For me it's 4700. Guessing it must be the switch off point as I can definitely hear my VCT solenoid click at just above idle when I give i give it a quick free rev. Can double check in sensor check later
Just for informations sake, specs on the corona.
1jz-gte
Hypergear TR44 turbo
Trust exhaust manifold
Trust 50mm wastegate
3" mandrel bent exhaust
500X300X76mm intercooler
3" intercooler piping
GFB Mach 1 BOV
2 front mounted gearbox oil coolers
Microtech LT12s and X6 igniter
X2 Excel radiator
No power steering or Air conditioning pumps
Techedge 2EO wideband o2 sensor
NOS kit (50 hp jets)
Greddy Profec B II
so it needs nos to get to 10.7? if so then what a useless post.
It did 11.8 without Nos. from that car's dyno reading:
The Nos added about 35kws. Those are old school turbos. The Fnt G3 he should be getting the same power curve without Nos.
Is this car still racing today?
Full boost at 2400 on a 2.5L, is that thanks to the stall converter?
My brother spools a 3037 .63 nearly at idle on a POS 2.6 Sigma. All thanks to a 2200rpm stall converter.
It ends up making all of 170kw at 18psi with the exhaust housing glowing white but it gives the illusion of a very different turbo.
Ahh the stall converter, applying load to the engine at idle to create some boost.
Here is a run from about 2500rpm to 6000rpm in 3rd gear on low boost(around 14psi). I know the dash isn't visible enough but this isn't something I want to try and do more than once on the road lol. My car seems to always ping now at high boost so I think the removal of the rubber hose has had an effect on the tune...
Edited by SargeRX8
You can find FNT feed back from Random in page 87. Check index on page 1.
Any way. lots of talk about twin scroll turbine housings. At this stage I'm not convinced that they has a "major" affect but welling to do some tests.
So, we all know the air gap inside the turbine housing is the height of the inducer blade of the turbine wheel.
By placing a metal strip in between and half the gap is actually reducing the area of the gap enabling higher air velocity. To me this is another way of sacrificing top end power for down low response unless the size of the turbine wheel and housing is in a reasonably large size.
Theoretically I can archive this behavior by reducing the gap height at only 60~70% of the turbine wheel top without the divider in the center.
I've done a drawing converting single scrolled turbine housing into a twin scroll item, internal or dual gate bolt on to stock setup of course. Good thing is I can setup dual effective FNT nozzles inside that housing for even better response. I'll be doing a back to back tests using a G3 core. hopefully it’s worth the effort.
Any way, Do post up if you have any experiences or back to back tests with single to twin scroll turbine housings.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
