Well the SS2 is more responsive, while the G3 pulled a bit harder up top.
I've got few more drawings for the G2 which I will have it made and tested soon. I'm hopping the new G2 can produce around 280rwkws using less boost based on similar or better response of what it currently has.
Some trailing with GenEses prototype was conducted this afternoon. That is the biggest hair dryer I've ever had. It drained my spare battery (my old car battery) in about 3 mints. I shot the last 5 secs before the battery died out. Will do further evaluations soon.
http://www.youtube.com/watch?v=2_k0aYiczFM
I've had the test car tuned current FNT ATR43G3's this evening. Basically straps on, internally gated on 98 fuel. The most it made was 330rwkws on 23psi, and 320rwkws on 20psi. The runs were performed with a high pressure actuator internally gated. The 20psi run is without boost controller.
The No.s were very consistant. This turbo doesn't get hot at all. Compare to the older G3 there is small difference on paper but huge in driving ability.
Also compare to the E85 Abe result based from the same turbo. It looks like E85 have made it producing more power and better response.
Stao I would love to see what E85 does to your current setup :thumbsup: .
what rpm does the electric charger do?
Will all depend on how much load it is under, eg if you are blowing it into a 10L motor with no restriction, or a 1.5L with conservative cams, one is going to load it up much more than the other.
I am very interested to see how it goes.
Stao if this electric turbo charger works, is it feasible to adapt it to a turbo charger so you can pre spool it? Eg run a belt or gear drive to a custom bearing housing so it can be turned on and off at will? I'm not sure how you would clutch it so it doesn't pose a restriction when on boost and you want to disconnect it though.
Did some testing today. It drains lot of battery, and I'm using 0 Gauge cable that turned pretty hot. taking it to a proper electrican to have the circuit loom made before pluging in to my car.
Some footages from today:
http://www.youtube.com/watch?v=MAqVTXEqBe0
Should be good for 5-10 second squirts then let it recharge. How will you bypass the turbine blades when it isn't in use as surely it will act as quite a large restriction, or will they free spin quite easily?
NO it doesn't spin when its not activated. So I've used low velocity wheel with a huge compressor housing. shouldn't create intake restriction on a small NA engine.
I've been testing it all afternoon, The Optima battery has no issues. Still fires and run after like 50 short runs. Would be similar to a Nos device that activates in short time pulses. This thing has no lag.
roughly 2 weeks if I don't run in to any more troubles. I've got a improved G2 design that I want to test out first. If all goes well we should be able to get close to the SS1PU's power, torque and response while not the extra coins and time making it.
How have you estimated it will make similar airflow as the G2 does?
Have you hooked it up to a flow bench to calculate how much flow it can create? Just not sure how you came to that figure.
Works every time right? :turned:
Flow bench only tells what the compressor can flow, how ever it can't predict how the whole package can perform on a certain engine. I prefer to physically test it, and after testing that many combinations I get a pretty accurate prediction of how things would turn out.
A Skyline amp is ~65amp, correct?
If that thing pulls 100amps, would beefing the generator system up to say 150amps provide enough stink to run it constantly? Or at least for much longer times than say the odd squirt for 10 seconds or so?
My issue with this (even though a good idea in theory)
Is the current draw, whacking a 300amp load on top of running fuel pumps, ECUs dash/head lights etc is going to make the car simply shut down.
In my car I can hear the fuelpump change tone ever so slightly when the brake lights come on and go back to normal 1/2 sec later, that would be 5-6 amps max, If I tried to whack 300amps on in 1 go the whole car would stop.
The other issue (if the car keeps running) is the huge voltage drop will affect the ignition and injectors and throw the tune out.
Still keen to see if it works though.
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
