I didnt touch anything. It's just not making as much boost now
I think either exhaust leak or intake leak. I know you pressure tested the intake, but I'm not convinced. These are the only two things that could really cause a big boost drop.
I personally had an issue where the wrong gasket was used in the two halves of the intake manifold, meant cylinder 3 and 4 were leaking badly but the rest sealed fine. Meant a boost drop in the high revs and was extremely hard to diagnose, went 2 years before finding the issue.
Could be something like this.
I think its best to send it back and swap for a FNT G3, I can give you my 330rwkws nistune map, load it in and see if that changes boost and power behavior, That turbo should also suit your driving style better.
Stao, the G3 comes with the big 3082/3540 .70 comp cover does it not?, have you tried fitting these comp covers to a stagea yet? If they do they must just about sit on the chassis rail. After beeing at my mates last night while he was fitting a 3076 with a 10mm spacer to a stagea, , theres only 10mm clearance to the rail with that setup and the spacer i have is 3-4mm larger spacer and the comp cover is much larger again .
cheers
darren
Edited by jet_r31
I can use. 60 comp housings thats not an issue. .70 fits fine on skylines with a 15mm spacer, including the actuator bracket it sits pretty close to the chassis. We supply the spacer as a part of the turbo.
Am I likely to have any fitment issues going from my current ATR43G2 (.63 housing) to the new turbo, Stao? Or is the 4" intake the only thing I should need to change?
Larger comp housing has better power to boost ratio, and keeps discharging temp lower. It has similar effects as having an larger turbine housing but not as significant. So unless special request all turbos above 500HP will be built with .70 comp housing as default. I've engineered the actuator bracket and spacer to fit stock exhaust manifold and dump. It will require a 4inch intake pipe with a pod and a 2.5 inches 90 degrees silicon pipe for the outlet.
The re-worked SS3 is fitted today and due for dyno test Tuesday. At this stage it feels similar to the G3 with noticeably better response. I'm hopping for around the 350rwkws assume injectors don’t run out.
Any way, my current SS-2 made super responsive 307rwkws on 20psi my dynosheet is at the rb25det dyno section.
I think we have brushed over this result. What a fantastic result from the SS2 307rwkw on 98 fuel with excellent response and full boost by 3600rpm!
Post #763 in the RB25 dyno results thread on page 39.
I think its worth also posting the dynosheets in this thread as well kwickr33.
I compared it to my SS1 result, SS1 makes 10-20kw more power below 3600rpm, same power at 3600rpm and then the SS2 kills it from then on by up to 50-60kw at some points!
Imagine E85!!!
There are my SS-2 results that I've posted in the dynosection earlier:
post-31034-0-87076600-1319554530_thumb.jpg post-31034-0-68326900-1319554610_thumb.jpg
The turbo is very responsive, with linear power delivery and super wide power band. It doesn't have much power spike. Super smooth on road.
I've also had an massive ATR45 for 2 years prior this turbo, that had a huge power spike after 5000rpms with short power band. How ever I recon that turbo pulled harder then the SS2 in high 3rd and 4th WOT, but drivability is no way near as good. The SS2 is definitely an excellent road performer.
Edited by kwickr33
I did want to ask, is that dyno graph yours?
The top of the graph says 'R33 Tao Hypergear'.....
Is that just a mistake or are you uploading the graph for that turbo off Stao's car?
Thats pretty good result. I've been testing the new G3 and SS3 lately, Any way, didn't go very successful last night the SS3 prototype with larger housing only made 316rwkws on 22psi.
compare to earlier run with 304rwkws it appears the smaller turbine housing actually worked better.
Going larger in turbine housing made no difference in top end power apart from gain lag. Not too sure if the exhaust manifold is causing restrictions or some thing else is stopping flow.
There has been few updates with std R33 and R34 high flows plus one new turbine housing that I want to trail for the G3. After those I will be going for a proper high mount setup with external gate trailing bigger turbos.
As far as stock bolton series, there isn't much point going beyond a G3 which is out flowing the stock manifold.
Stao do u mind posting a close up clear view of your engine bay - I would like to see a close up view of your 4 inch metal intake pipe, Z32 mounting and turbo/ actuator/ dump if possible.. Trying to set my car up like yours, it is off the road now and I'm thinking of getting one of your turbos as my final mod...currently I need the injectors, Z32, dump and 4inch intake.. cheers :cheers:
Terry thats a very impressive result, does this turbo suck you back HARD into your seat?? Thats what I'm after, a very responsive 280-300rwkw hypergear turbo that throws u brutally on your seat..:thumbsup: - quick and hard response -- dunno which one I need SS2 or SS1.5 or SS pu --- very confused..
Agree that hitting 4k on traffic to get boost makes u look like a wanker, so out of those three turbos above, Im still confused which is the smaller one - am looking for min or at least 280rwkw and very possible 300rwkw..
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
