Sounds like your pretty sure of that, what have I done wrong.
lilcrash - I haven't done a long search, but reading through this thread shows you have problems with your car that you keep bringing up in here.
Have you created a seperate thread about the problems you're having to see if the greater SAU mob that don't visit the HG thread might be able to help with?
All I've gained in the last 10 pages or so is that
- you have a HG turbo.
- your car runs like shit.
- your car makes no power
- your car is very laggy compared to others with the same turbo
- it loses all power after 5 minutes.
Just because this all started happening after the turbo install doesn't mean that the turbo is the fault.
start a new thread.
list all the problems.
list everything you have tried so far.
post dyno graphs or a dump of your tune etc.
I have been reading all your posts going back a while, when you have been doing the inlet pressure test have you had the throttle open or closed? If you havent it might be an idea to try that, on that idea I am not sure whether that would blow through the motor and you lose pressure out of the exhaust, if it does I would get a blanking plate at the cat and bolt it on, then you can check everything.
Another thing what boost control are you using? Can you borrow a turbotech and check to make sure it can be ruled out, I know you had a turbo smart boost tee, I have found them to be terribly unreliable for consistant numbers and runs on the dyno.
In the first post in the thread stao said he had valve float which caused boost leak and sloppy response it might be something else to consider.
I guess you also did the other basic checks like static ignition timing, leakdown and compression tests?
Edited by Stevoss
Be nice to other members after all we are trying to solve his issues. I've just got my order of the super high strength actuators I will send you one this afternoon. Strap that on and see if that changes boost behavior. If not then you are welcome to send it back for exchange for a G3 unit which are welly proven, If it still has strange boost behavior then its going to be abit out of my hands.
so whats new with the new highflows?
i think thats the route i will take when i finally get my act together/i stop getting hassle from my other half
The std high flow profile was updated late last year and been used since. They should produce abit more power then the earlier profile, how ever I've only got one dyno sheet from Toshi's customer whom's made 260rwkws out of 21U rear housing, which is little bit more then what I originally expected.
I think the current 21U high flow profile should do around 240rwkws while the OP6 should be around 260rwkws.
Be interesting to see what the lastest PU .82 hi-flows now make with the updated FNT etc, seeing as they are the same as the latest G3's (330rwkw) except
for comp cover?, be interesting to see how much the standard comp cover chokes it
cheers'
darren
so what would be the cheapest setup to max out the stock setup? (run injectors and afm to a safe max)
op6 highflow?
Std high flow with a ECU will do fine with stock setup. Also Toshi got that guy 260rwks with std high flow and factory setup. I've noticed you can do closed loop injections with some ecus but unsure about remaps. if so then you might be able to get to that power level.
cool cool, might have to get mine highflowed soon then
rough price for that? including lines?
and whats closed loop injections?
With stock injectors?
What is 'close loop' injections? As in different type of batch fire or something that means the injectors pulse more often?
Edited by Rolls
Yes. this guy. apparantly thats on a 21U R33 turbo high flow running toshi's mail order ecu on stock injectors, you might want to ask toshi to see what he's done on the injection duty cycles. Not too sure if the dyno's accurate but thats only result I've got from the updated profiled high flow units this year.
I wouldnt do it...but some guy made 260 something on a standard ECU!! (thread on here somewhere)
Was done by making it laggy so it missed the R&R point.
But yeah, Closed loop at cruise would make it not run mega rich, But I dare say it would be quite rich coming onto boost though.
I guess if you could get the injectors to pulse more often or you modified the pulsewidth it could be possible, that or using an aftermarket fuel regulator.
At 100% there is no pulsing. The injectors stay open
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
