The boost level seems to be affected by temperture. Just had few very hot days in Melbourne and the high pressure actuator seems to be holding 18psi instead of the 22psi when its cool.
Also shouldn't the engine run rough as with the tooth skipt on the cam gear?
I'll be looking at getting a hypergear hiflow done soon (as I'm only going to be chasing around ~230rwkw) and will have two turbos available:
a stock 45V1 VG30 ball bearing turbo, and a stock 45V4 on my 1996 series 2 RB25DET
Which one would be better suited for hiflowing with responsiveness being the priority?
Can Make around 260rwkws with the VG30 turbine housing. stock Rb25det housings are good for around the 240rwkws mark. Either of them would be good enough for the goal of 230rwkws.
Under that rubber pipe is just a white plastic hose that dumps condensation when A/C is on. The water comes in due to the car's acceleration momentum, get a rubber plug in that size then cut the center section out for that plastic hose. That would stop any water drain in to the cabinet.
Just had a look then and my a/c rubber pipe doesnt have any white plastic hose underneath? The whole top half of the black rubber a/c hose is burnt on mine. Couldnt work out where it comes into the cabin or how to put a rubber plug anywhere??
There is a white coloured hard rubber pipe under that rubber, water comes out of there when the A/C is on. Just make a plug from a bit of materials in Clark rubber for the frame and cut a hole in the center for that plastic pipe. That would stop any water drop draining into the cabinet. or just connect what ever bit of hose on to that pipe.
Is your dump a JJR item as well?
Mine is just flexi rubber hose, I can bend it and because the whole front is melted I can see inside and theres nothing white inside.
I cant workout where it joins inside the cabin.
Yes its a JJR dump pipe.
Seems to be an common issue using HG turbo on JJR front pipes. Pull that rubber piece off and there is a hard plastic pipe in it. Water comes out of there.
Edited by GeorgesR34
am interested in this as i will be going HG in a couple months. since my engine bay is stripped out ill try to get detailed photos up tonight so we can all have a good look :thumbsup:
That would be awesome if you can take some photos so we can all have a good look!! Hard to see with everything in the way.
Hey Sarge hows ur new intake pipe and lean popping issue? I just ordered me a set of YJ coilpacks, did u have issues with yours?pinch.gif
Lean popping wasn't an issue, I don't think. There was nothing there causing the lean pop and after fitting the AFR gauge it was showing that it was running around 13's which alot of have said will cause lean pop. I got rid of it by richening up the idle mix. Some people run 17.1 afr on idle and they put up with lean pop, I tried it and f**king lol no way in hell. It sounds like shit and the car feels like a rough v8 on idle. New intake pipe should be good. No more rubber or tight corner, a nice 90 degree 3" all the way through. It seems to have fixed my coming off boost stalling issue!
I had issues with them, I got a refund and got brand new OEM coils.
I found when I angled the bov return and pcv valve return towards the turbo inlet and away from the afm it solved my off boost stalling issue.
;) Its not so much the breather line as that is just under vacuum, no air gets pushed through it, shit is sucked through it, its more the BOV return which if when it releases the boost in the system, it hits the AFM, it goes into a fueling mode, adds fuel and stalls.
I think you hit the nail on the head with this statement. I remember u had a lean popping issue when u changed ur intake earlier, and maybe this was the reason above. Where'd u get those two little breather pipes with the rolled edges thats welded onto ur intake?
When I made my intake pipe, it was near impossible to run the standard BOV return so I chopped off the end and rather than throwing it out, I used it as the bung to weld on. If you are anal about it and want the edges rolled like that, buy another one that someone is selling (they are cheap) and cut as long or short as you need to line up with your bov return. I also ran a catch can so the hard return line for the oil side wasn't necessary.
so looks like if the hose gets blocked it will flood the car. also if its squashed or pulled in the wrong direction it will also get into the car. i might try cut it a little shorter and slip a bit of hose over the white tube and have it running down the inside of the black hose.
i cant see how the hose melting makes the water get into the car unless its blocking the hose when it melts
Edited by t_revz
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
