Definately. I have another 2 hypergears to tune soon. Well 1 until Kasko buys his ss1
You'll most likely make that 3 soon, I called you Wed night - still pretty keen to let you tune the SS2 on my auto GTT
See the way I see it if you are running the max airflow a turbo can provide at redline, then that same airflow at x psi will be x+y psi in the midrange, hence you should run more boost in the midrange to make the most of the turbo.
Like if you look at the compressor map then the same airflow at redline at 20psi is 25psi in the midrange. So if you can get away with running more boost at redline, you should increase the midrange boost to make the most of it.
Which is why I think turbos should be set based on airflow not psi. Though if you do it this way you are always going to have a massive midrange spike and have torque fall off by redline which just doesn't feel as good for some people, though for drifting etc it is perfect.
Thoughts people?
Well for a start you will have a LOT more cylinder pressure around peak torque, where you don't want it..
cheers
darren
Edited by jet_r31
Look at the 3L TT inline 6 BMW engines, all sorts of trickery to keep the torque flatish and not have massive peaks like our cars.
But the sharp rise is what makes a fun street car and makes passengers grab the jesus handle. ;)
JET 31 - Why dont u want maximum torque? Thats the funnest part, yes its more det prone there but if the fuel is good enough then there is gains to be had, then let the boost build to redline and make crazy power figures.
If only...
Tao i agree, E85 is cheating. 98 is the devil.
I think its more to do with the wastegate gate setup. When Trent did the internal and external gated test, the hug drop in internal gate setup means the turbine is cooping with high exhaust manifold pressure as well as heat after certain rpms.
From experiments that I've conducted a large external gate acts as a secondary turbine that carries out compressor flow only when needed.
So getting good results from an internally gated setup: Comp flow = turbine flow
on the external gate perspective: Comp flow = Turbine flow + External gate flow.
As if I run G3 compressor onto a SS1PU's turbine with a large 60mm external gate, I should get the 300rwkws peek power from the G3 while having the 20psi by 3300RPMs response of the SS1PU. I will do some tests on that when I’m over with stockie boltons.
cheers
darren
You always have peak cylinder pressure at peak torque... that is what peak torque is. What I am saying is you can increase your midrange torque for any given redline torque if you are running flat boost. Assuming of course you are not limited by detonation due to fuel etc.
Tao i proved exactly what u are saying with my old sr20 and .6 disco potato. I changed it to a 50mm external gate setup and made an extra 15-20kw all over. Its amazing how much extra the car can breath
If only...
its a traction thing..its the way the max toque is delivered..
I know my with old turbo came on so much smoother with a factory airbox even ,just putting the pod on it would make it snap noticably harder into boost/max torque making it easier to lose traction ,which is fun but I prefered the smoothness and tractability with the airbox, even if it was making a few kw less...I could feed power on hard without slipping around or kicking out so much..
Guess it depends if you want to slide or drive..
Ur on ur own with that one. I see it as even if u have the power to break traction, with the correct throttle control u can be just as fast
IE me and you testing animals in the rain lol
Im just sayin it was a little easier to drive, not as much skill needed just smash it and go...
Sure you can do anything with "correct throttle control" but hey, if you have skill you dont really need synchros in your gearbox either...but they sure do make life easier...lol
Some Modifications that I've done to a stockie R33 21U turbo:
4inch inlet adaptor with SS3 comp wheel:
Looks all sort of stock I guess.
Would be awsome if I can crack 300rwkws with it internally gated on pump 98. :D
does it really need to be 4"? lol
cant it just be 3"?
Nope, the comp inducer is larger then the 2.5 inch inlet they had there. Had nothing left to clamp hose on after machining. lol
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
