The logic & experiences of the split dump pipe being a restriction makes sense to me explained in that way. Thanks GTSTScott, Rolls and Birds for the explanation.
In any case buying one of these is not a hugely expensive gamble for me, so I will just have to wait a while, get one & sell the current one, and see how it goes.
Because retuning is fairly expensive though, I may want to make more changes than just the dump pipe to make more sure of getting more power. Finding out the dump didn't work & that it is indeed the FMIC after another retune would be a bit painful.
Another point to note; when I was speaking with Tao, and he asked what intercooler I have, he was of the opinion that even having a FMIC running the normal path (not turnflow), the only coolers he had seen consistently perform were Plazmaman ones and PWR (which he has on the test car). I asked about Blitz turnflows and he does not think these are reliable either, and definitely not anything JJR.
The problem with the JJR return flow and short vertical run down cores, is not the ability to flow, its the ability to loose heat. They pull one good run then heat soaks every run after, so your car would pin, pin, and more pinning after each run. Don't remove timing, give it 20 mints cooling period between runs and its knock free. I've already tried that and mentioned it in earlier pages.
Obviously when running E85 with a cooler like that, the fuel is not as sensitive to heat, so as long as it can flow it will make power.
I believe Jeff wrote a full page long about testing of a blitz return flow cooler that caused boost drop issues, if you haven't seen it please refer to index page for the thread.
In conclusion don't use return flow coolers or crappy cores for 300rwkws application. Spend some cash and get a decent plazaman cooler (abe's car G3 making 290rwkws pump and 358rwkws E85) or a PWR cooler (test car). The importance is in the quality of labor work, and materials its made from.
Split dump will do no good. It causes boost creep and flow restrictions specially used on the G3. There has been few pages of discussions to read at, they can be located through the index page.
Plus there is no magic in the engine. Every single part in its build is listed in previous pages.
My return flow is performing so far. I also have cooler piping from turbo is 2inch then near the cooler it opens to 3inch. Then from the cooler it drops from 3inch to 2.5inch to the throttle body.
This car goes against the norm
yeah mine is only 60mm all the way to the cooler too, then 2.5 to intake..not return flow though..
Smaller piping helps keep up velocity up which is good for response..thats my theory anyway..;)
probably not great for big power though
Silicon will be alright for a 250-260kw setup?
yes, with abuse it may give way over time but should be fine for ages..
Hey Guys
So this is what I mean by the welding its right near the sensor
Ah mine has a ridge about half an inch behind the flange. You have the same ridge but mine seems to have separated and is now raised. I'll try get a photo up later
As long as there are no kinks/abnormal stresses on the joiners, and the surfaces being joined together are free of contaminants, I'm absolutely positive there is no way you'll run a higher boost pressure than they can handle. Quote me on that.
Also 150rwkw @30psi is more likely to blow joiners apart than 700rwkw @15psi.
Oh also, I'm fairly sure that my boost source is plumbed much further than 30cm from the turbo...it's on the cold side of the intercooler piping, as it goes back over top of the turbo.
I wouldnt say dont use return flow coolers
i have a ARC return flow on my 33 with my gt3076 yet to be tuned
but my best mate has one on his r33 and makes 307rwkw on 18psi internal wastegate with a ARC and doesnt see any pressure drop or rises in intake temp
i guess its all todo with the quality of the cooler
i would always prefer a more expensive cooler to retain the LEGAL well the stock HOLE route rather then cutting a hole
Is there a certain way about doing it?
Hot side or cold side of the intercooler
When you say back over the turbo Troy do you mean just before the throttle body?
nothing wrong with cutting a hole if it is done in the right place.
not entirely true, NYTSKY's R33 GTST made 427rwkw with a china spec 76mm front mount intercooler
Not quite that far, more around where the cold side piping goes back over the pod filter. Either way,like 40cm before the throttle body
In Melbourne Vic roads new law in there book says no holes to be cut in the body if it's not from factory, can't even cut out a parcel shelf to fit 6x9 speakers
In that case you could very easily go to a mech engineer and get them to sign off on it if it is a non structural part of the vehicle. There is ZERO issue with cutting into non structural parts.
Makes no sense to me.
Its good to be consistent in what we talk about dude.. Try to remember an ARC cooler goes for 1-2000 dollars new, its not exactly apples and apples when you think of it that way.
Long story short, ARC are a fu*king good cooler.
A good example of this is the 3071 with a 0.63 rear that made 307rwkw on a neo r34 with poncams, made 290 with stock cams, only ~18psi as well, was tuned by one of the guys at nistune themselves and on the morpowa dyno here in Adelaide, reputable tuner and not known to be high reading dyno by any stretch. The dyno picture is in "matts r34" thread on the nistune forums if anyone wants to check it.
Guy had all of the most expensive jap brand name (overkill) parts as far as intake, intercooler, exhaust, dump etc goes, the engine was also extremely healthy (neo as well). I think this really shows the merit in good quality parts, no leaks etc as this result is normally what is seen on a gt3076 with a 0.82 rear.
In regards to where to get your boost reference signal from..
The way I like to do it is for the actuator, shortest possible path, as close to turbo exit as possible.
I then get the boost reference for the EBC control unit from the plenum.
This is how my stock turbo was setup but now going to have to use a silicone joiner
So I will do just after the joined but before the intercooler
Right now my EBC gets reference from the stock gauge line
Just after the elbow is fine, you just want the actuator reference signal as short as possible (i.e. not on other side of the cooler) to prevent any overboosting or lazy signal issues.
My new setup will have a peak recall boost gauge plumbed in with the actuator reference signal (so I have pre cooler readout) and a normal boost gauge + EBC signal (EBC has peak recall) at the plenum. This will then show me any pressure losses and help troubleshoot issues :)
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
