Just realized they said there was boost control issues so I guess that would be affecting power up top a fair bit as well.
If it was holding boost to redline I still think itd be 250+
I wouldn't expect it to be hitting 270kw on 20 psi with a 15+ yr old motor.
Edited by Mitcho_7
Wait for the charts gentlemen, no point speculating over power figures or what's responsible for them until we see what the engine is doing. As JEZ said, there's probably a bit more in the turbo if they take the time to sort out boost etc. but for now Kasko should be pretty happy and he looks to be.
Very smooth. Boost tapering off = another 10-20 if you can get it to hold without the engine pinging?
Full boost looks like high 3000's / 4000rpm, I'm guessing.
  • Like 1
Need ebc to hold boost up top. I'm testing a little mod this weekend and hopefully that changes the boost behavior up to.
Already got a profec b spec 2 installed in it
This didnt help with the tapper.
Seems the actuators are not up to holding the 20psi consistently
Also as DVS said it seems my clutch is either on its way out or needs a bit of adjusting/bleeding
The car feels phenomenal when it comes onto boost and spins 2nd without hesitation cruising.
Next step is a CAI and a box for the pod filter might help a little.
We did back to back power runs on a safer tune and only lost around 1-2kw
Is that same turbo you have birds?
Yeah man.
How bout that! :)
What size tyres you running?
Assuming it's 4.11 diff ratio and normalish sized tyres is nearly at full boost at 4000rpm with 180rwkw
Not exactly comparable with a GT-RS
180rwkw @ 4000rpm IS comparable to a GTRS, I agree.
Forget about where it hits full boost etc etc. The power @ RPM will tell you what its doing flow wise, which is what counts.
Every decent turbo makes 180-200rwkw at 4000rpm on a RB25... It can be a T67, 3071, 3076 or HKS 2835pros, they all do it
It's what happens before and after then that makes the turbos different!
Edited by SimonR32
Yeah, so doesnt a GTRS do roughly 180-200 @4000 and end up around 250 by 7000? LOL
So its more or less hitting GTRS benchmarks, OK glad we agree. :whistling:
If the turbo can hold boost for the upper RPM, there's no reason it can't make 260-270 IMO, so no it's not comparable to a GTRS...it's slightly better :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
