Have elusivity's car here at the moment. Waiting on my fuel pressure and flow gauge to arrive so i can set the turbosmart reg and then start tuning it from scratch.
Hoping it will be able to match the td06 i did yesterday or very close to it
Well all is going good. Hitting full boost before 4000rpm.
But i cannot get the boost to hold to redline.with the eboost2 I have tried:
-correction factor from 4.4k to 7k which does nothing
-tried rpm set points with 100percent up after 4.5k which does nothing. It just keeps tapering off.
Having some dinner than gonna finish tuning. Will try up to 21ish psi.
This is a ss2 with .63 and 15psi actuator
That's not bad for auto. The lever worked fine, check last result. Im testing the wast gate lever on the ss1pu at status right now. Will post later.
Its a race bulb. It only comes on above 17psi. All R34's do it with NIStune or stock ecu. Its the boost pressure sensor that makes the DTC come on which inturn puts the check engine light on.
NIStune recommend leaving it on instead of turning the DTC off. Reason being if the customer or anyone else unplugs the boost sensor ontop of engine and it doesnt light up then issue's can arise. Ask hanaldo about 34 ecu's and DTC's.
No don't, I don't wanna talk about it :glare: lol.
I'm now quite sure that my check engine light has been wired into one of the other dash lights. It comes on with the key switched to on, but never once with all the DTC's I've had has it come on while driving.
.63 housing really killed the power hey :unsure: what mods are on it?
98 R34 GTT - Auto
Blitz return flow
Trust PE II
HKS pod + z32
3" Hard metal intake - with some silicon joiner, may need to get it replaced if DVS Jez reckons it's causing issues
Hypergear ATR34 G3 0.82 rear
Hypergear ATRSS2 0.63 rear
TurboSmart Eboost 2
TurboSmart FPR800
Walbro intank
Bosch ID 1000cc Inj
NGK BKR7ES copper spark plugs, gapped ~1.1mm
MV Automatics Stage 2 kit - valve body + welsh plugs +
MV Automatics Billet 2nd gear servo
Nistune
Running KU31 255/30/19 on the rears
The .63 housing may have killed the power but it is an auto and I wanted response, and something over 250kw, and I won't go into previous tuner issues which made me steer away from an already installed G3.
Hopefully Stao doesn't mind the comparison and my borrowing his images.
Stao may be able to comment on this person's mods more, but I'm pretty confident with my setup and like Jez I'd like to see this new actuator arm fitted up and see if we can pick up more top end.
Auto R33 GTS-T customer of Stao's his made very similar power, with less boost, but very similar kind of boost drop off.
Autos are awesome in turbo cars, totally underrated IMO. Best example was the auto that came with 1JZ Soarers!
I agree, I love the overall responsive feel of a built Auto box - I also drive 45-60 each way to and from work each day through backstreets to avoid bumper to bumper traffic, far easier to just coast through in drive rather than clutch and shift every 30 - 90 seconds.
Birds come and get this part after clutch change. The turbo will be able to hold 20psi straight to 7000RPMs with it using a EBC. Should get around 280rwkws with extra 3psi of boost.
That part is $35 delivered. It's best working with the 14psi actuator and ebc. It will only work assume the cause of the drop is the strength of actuator. Will have no affect on retriction related boost drops.
Stao, sign me up, do you need a PM with details again? Or you can deliver to Jez, as I'll be asking him to fit and retune, hopefully able to pick up another 20kw and hit my 280rwkw goal? :D :D :D
The boost behavior from the lever extender results in better overall boost control for internal gate. Sure I can make one for you.
I will take time sharing my experience about fuel injectors. I've had a set of 800cc Power enterprise injectors (costed $998) installed by Trent today for E85 in few weeks time. A drive from where I'm to Status is a $50 investment on fuel with the ebay $500 550ccs that came off, using the new injectors I've gained about 150% extra mileage, and the car drove noticeably smoother. The branded injector's got much finer spray compare to the none name high flows that runs like a tab. Definitely cheaper in the long run.
Today we've did couple of runs on a smaller and more dynamic version of the SS1PU. How ever responsiveness gained is based on the lose of top end power, So it will remain as a prototype for the time been. The more responsive runs are from today.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
